Igot the an error LNK2019, imsls_err.lib(flexlm.obj)
error LNK2019: imsls_err.lib(flexlm.obj)
when compiling a Dynamic Library below, Ihave any idea for this, please give me an answer. thank you very much!
module MM
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
include 'link_fnl_static_hpc.h'
USE numerical_libraries
real:: A(2),B(2), INV(2,2)
END MODULE MM
MODULE FF
INTERFACE
subroutine Dis
Use MM
end subroutine Dis
END INTERFACE
END MODULE FF
subroutine MainSub(AA,BB)
!dec$ attributes dllexport :: MainSub
Use MM
use FF
real:: AA(2),BB(2)
A=AA
B=BB
call Dis
end subroutine MainSub
subroutine Dis
Use MM
implicit none
real :: C
INV=reshape((/1.0,0.0,0.0,2.0/),(/2,2/))
C=BLINF(2, 2, INV, 2,A, B)
print*,C
end subroutine Dis
module MM
END MODULE MM
MODULE FF
INTERFACE
subroutine Dis
Use MM
end subroutine Dis
END INTERFACE
END MODULE FF
Use MM
use FF
real:: AA(2),BB(2)
A=AA
B=BB
call Dis
subroutine Dis
Use MM
implicit none
real :: C
print*,C
end subroutine Dis
You need to provide more information if you expect to receive help here. For instance, we need to know the compiler version, your OS, the version of IMSL used, the compiler and linker commands used, etc.
With IVF 11.1.070 - X64, IMSL FNL6 - X64, on Win7 Home X64, with a standard setup of the environmental variables, the above code, put into a file called dimsl.f90, and compiled using
[bash]D:LANG>ifort /LD %F90FLAGS% dimsl.f90 %LINK_FNL_SHARED%produces dimsl.dll with no problems or error messages.
Creating library dimsl.lib and object dimsl.exp[/bash]
mecej4:
thanks you for your help, My compiler is : IVF 11.1.051, VS 2008, IMSL6.0, I compiling the codes under VS2008 .Iam notfamiliar withcommand line.would you mindanswer me again.thanks you very much.
zlzgj
zlzgj
I do not have a version of IMSL that was bundled with IFort; therefore, if you have a bundled IMSL, there may be a VS2008 option for IMSL that you just select.
Choose a Fortran DLL project. Add your source file.
To Project:Properties:Fortran:General:Additional Include Directories, add the Include directory of your IMSL installation. For example, c:\LANG\vni\imsl\fnl600\Intel64\include\dll
To Project:Properties:Linker:General:Additional Library Directories, add the Lib directory of IMSL; for example, c:\LANG\vni\imsl\fnl600\Intel64\lib
To Project:Properties:Linker:Command Line:Additional Options, add the following (or as appropriate): imsl_dll.lib imsls_err.lib lmgr.lib
Build.
Build.
ztzgj,
You are not using the IMSL provided by Intel. Please contact Visual Numerics for assistance with that version. How can I tell? The reference to flexlm.obj, which is not in the Intel variants.
Hi, mecej4
According to what you said, I did it. thanks!
zlzgj
zlzgj
steve Lionel
The problem has been solved. thanks for your help.
zlzgj
