29541 Discussions
ICE: Function `associated` bug for Intel Fortran compiler (ifort)?
zoziha
Same as: Function `associated` bug for Intel Fortran compiler? - Help - Fortran Discourse (fortran-lang.discourse.group)
The following code will cause ICE (Internal compiler error) to occur in `ifort`:
module test_m
    implicit none
    private
    public :: f, set_method
    ! local procedure pointer
    procedure(func), pointer :: f
    abstract interface
        function func(x)
            character(*), intent(in) :: x
            character(:), allocatable :: func
        end function func
    end interface
contains
    ! set method
    subroutine set_method(ifunc)
        integer, intent(in) :: ifunc
        if (ifunc == 1) then
            if (.not. associated(f, starts)) f => starts ! This line
        elseif (ifunc == 2) then
        end if
    end subroutine set_method
    function starts(x)
        character(:), allocatable :: starts
        starts = ">"//x
    end function starts
end module test_m
program main
    use test_m
    implicit none
    call set_method(1)
    print *, f("string")
end program main
I suspect it is related to `associated` function, remove the `associated` judgment code to compile and pass:
    ! set method
            f => starts   ! Note here
Ron_Green
definitely a bug.  I'll get a bug report started and will update this post and the fortran-discourse with same.
Thanks for bringing this to our attention.
Barbara_P_Intel
I filed a bug report for this, CMPLRIL0-34800. Will post when a fix is available.
Barbara_P_Intel
The ICE when using ASSOCIATED() is fixed in the current release of the compiler. It was made available in December and is part of oneAPI HPC Toolkit 2023.0.
Try it out!
