29531 Discussions
Simplification of FINDLOC with array of size 0 fails
Harald1
New Contributor II
The following code is rejected by ifort 2021.6.0:
program p
! integer, parameter :: ii(1) = findloc ([integer::1],1) ! works
  integer, parameter :: ii(1) = findloc ([integer:: ],1) ! fails
  print *, ii
  print *, findloc ([integer::],1) ! accepted
end
This gives:
% ifort ifort-findloc.f90
ifort-findloc.f90(3): error #6821: A scalar constant is required in this context.
compilation aborted for ifort-findloc.f90 (code 1)
It shouldn't be too hard to do the simplification...
Barbara_P_Intel
I filed a bug report on this erroneous error message, CMPLRIL0-34931.
Mark_Lewy
Valued Contributor I
I'd argue that this is a compiler bug as
looks like a legitimate constant expression (according to MFE 8.4).
I note also that gfortran --warn-all (MSYS2 10.2.0) compiles this without any warnings and produces the desired output.
Barbara_P_Intel
Barbara_P_Intel
This FINDLOC() issue is resolved in the latest Fortran compilers that were released in December. Give it a try!
Harald1
New Contributor II
Yes, it is fixed in the latest version.  Thanks!
