ICE: TBP 11.1.069
Alexis_R_
I get an ICE with 11.1.069 (20100203) when compiling the following code:
[fortran]module mod_image
	TYPE IMAGE
		!INTEGER, KIND					::	VALUE_KIND			!< Kind of REAL or COMPLEX array to use for memory storage
		INTEGER							::	DIM(3)			=	(/1,1,1/)	!< Logical (X,Y,Z) dimensions of the image.
																			!! Note that this does not necessarily correspond to
																			!! memory allocation dimensions.
		LOGICAL							::	IN_MEMORY		=	.FALSE.		!< Whether image values are in-memory. Default = .FALSE.
		CHARACTER(LEN=4)				::	TYPE			=	'REAL'		!< Type of image: 'REAL','COMP','DBLE','DCMP'. Default = .REAL.
		LOGICAL							::	ORIGIN_AT_CENTER =	.TRUE.		!< Whether the origin is at the center of the image.
																			!! Assumed to always be true in real space, but set
																			!! appropriately by FT routines for reciprocal space.
		REAL(KIND=4), ALLOCATABLE		::	RVALUE(:,:,:)					!< Real array to hold values for REAL images.
		COMPLEX(KIND=4), POINTER		::	CVALUE(:,:,:)					!< Complex array to hold values for COMPLEX images.
		! not used - to be removed
		REAL(KIND=8), ALLOCATABLE		::	DRVALUE(:,:,:)					!< Double precision array to hold values for DBLE images
		COMPLEX(KIND=8), POINTER		::	DCVALUE(:,:,:)					!< Double complex array to hold values for DCMP images
		CONTAINS
			PROCEDURE	::	ORIGIN_COO	=>	ORIGIN_COO
	END TYPE IMAGE
	CONTAINS
	!>	\brief	Returns the integer coordinates of the origin
	!!	\todo	Ensure this is called in all relevant subroutines, which should help smooth behaviour with even/odd dimensions
	PURE FUNCTION ORIGIN_COO(SELF)
		IMPLICIT NONE
		! Arguments
		CLASS(IMAGE),	INTENT(IN)	::	SELF
		! Result
		INTEGER	::	ORIGIN_COO(3)
		! Private variables
		INTEGER	::	I
		! Start work
		IF (SELF%ORIGIN_AT_CENTER) THEN
			DO I=1,3
				IF (MOD(SELF%DIM(I),2) .EQ. 0.0) THEN
					! Dimension is even
					ORIGIN_COO(I) = SELF%DIM(I)/2+1
				ELSE
					! Dimension is odd
					ORIGIN_COO(I) = (SELF%DIM(I)-1)/2+1
				ENDIF
			ENDDO
		ELSE
			ORIGIN_COO = [1,1,1]
		ENDIF
	END FUNCTION ORIGIN_COO
end module mod_image
program test
	use mod_image
	implicit none
	type(image)	::	img
	print *, 'Hello world', img%origin_coo
end program[/fortran]
The compile command & ice:
[bash][alr99@kiev build1]$ ifort -c ../main.f90
../main.f90(61): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ../main.f90 (code 3)
[/bash]
Alexis_R_
Interestingly, adding parentheses after the TBP call solves this issue. I.e. replacing line 61 above with:
[fortran]print *, 'Hello world', img%origin_coo()[/fortran]
Kevin_D_Intel
Thanks for the reporting this. I reported it to Development, noted the internal tracking id below, and will update the thread as I learn more.
(Internal tracking id: DPD200151137)
Kevin_D_Intel
The fix for this issue is expected in next 11.1 update 6 (tentatively in the April/May '10 time -frame).
Kevin_D_Intel
(Resolution Update on 04/26/2010): This defect is fixed in the Intel Fortran Compiler Professional Edition 11.1 Update 6 (11.1.072 - Linux).
[bash]ifort -V -c u72168.f90
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414 Package ID: l_cprof_p_11.1.072 Copyright (C) 1985-2010 Intel Corporation. All rights reserved. Intel Fortran 11.1-2739 u72168.f90(49): error #8319: An EXTERNAL procedure name must not appear in an input/output item list. [ORIGIN_COO] print *, 'Hello world', img%origin_coo -------------------------------^ compilation aborted for u72168.f90 (code 1) [/bash]
