ICE and related issue with overriding binding
Neil_Carlson
I've attached an short example code that causes an ICE with the just released 13.1.1 compiler (and presumably earlier). The example includes a variant that doesn't result in an ICE, but which results in what I believe is a spurious fatal code error.  The code defines an abstract type and an extension of that type that overrides a deferred function binding.  The compiler asserts that the characteristic of the overriding function result differs from the interface of the deferred binding.  I don't believe it does.  The details, including references to the standard, are in the header of the example.
Regards,  Neil
Neil_Carlson
Here's the example code.
Steven_L_Intel1
Thanks - I have escalated this to the developers as issue DPD200242779. It's similar (but not exactly the same) as http://software.intel.com/en-us/forums/topic/372776
Anonymous66
Valued Contributor I
A fix has been found for this issue. We are planning to include it in the next major release which is currently scheduled for later this year.
Annalee
