29358 Discussions
ICE and segfault with ifx and ifort for select rank and select type of class(*) argument
martinmath
ifx (2023.0.0 20221201) aborts with an ICE, classical ifort (2021.8.0 20221119) compiles but segfaults. (The code is boiled down from a pretty printer routine for debug purposes.)
program select_rank
implicit none
real :: x
integer :: y
x = 4.56
y = 5
call p(y)
call p((nint(x)))
call p(nint(x))
call p(fun(x))
contains
   function fun(x) result(y)
      integer :: y
      real, intent(in) :: x
      y = nint(x)
   end function fun
   subroutine p(v)
      class(*), dimension(..), intent(in) :: v
      select rank (v)
      rank (0)
         select type (v)
         type is (integer)
            print *, 'rank 0', v
         end select
      rank default
         print *, 'rank not supported'
      end select
   end subroutine p
end program select_rank
Ron_Green
Ouch, a bug for both ifx and ifort.  I'll write it up.
martinmath
Those compilers are not alone The code is from a gfortran bug report. Hence the different variants of how to call the subroutine p. Not all are handled by gfortran flawlessly.
Anyway, thanks for taking care.
Ron_Green
Thank you for sending this to us. the bug ID is CMPLRLLVM-43747
martinmath
Here is a variation, which also fails. I post it as the first testcase runs fine with current gnu fortran, but this new one fails with gfortran as well.
module mod
implicit none
private
type, public :: t
   integer :: i = 65
contains
   procedure :: get
end type t
contains
pure function get(self) result(i)
   integer :: i
   class(t), intent(in) :: self
   i = self%i
end function get
end module mod
program select_rank_tbproc
use mod
implicit none
type(t) :: x
class(t), pointer :: y
allocate(y, source=t(73))
call p(x%get()) ! fine
call p(y%get()) ! segfault
deallocate(y)
contains
subroutine p(v)
   select rank (v)
   rank (0)
      select type (v)
      type is (integer)
      end select
   rank default
   end select
end subroutine p
end program select_rank_tbproc
Barbara_P_Intel
Thank you! I added it to the bug report.
Ron_Green
I just confirmed the fix for this bug is in the 2024.1.0 compiler.
