ifx (2023.0.0 20221201) aborts with an ICE, classical ifort (2021.8.0 20221119) compiles but segfaults. (The code is boiled down from a pretty printer routine for debug purposes.)
program select_rank
implicit none
real :: x
integer :: y
x = 4.56
y = 5
call p(y)
call p((nint(x)))
call p(nint(x))
call p(fun(x))
contains
function fun(x) result(y)
integer :: y
real, intent(in) :: x
y = nint(x)
end function fun
subroutine p(v)
class(*), dimension(..), intent(in) :: v
select rank (v)
rank (0)
select type (v)
type is (integer)
print *, 'rank 0', v
end select
rank default
print *, 'rank not supported'
end select
end subroutine p
end program select_rank
Ouch, a bug for both ifx and ifort. I'll write it up.
Those compilers are not alone
Anyway, thanks for taking care.
Thank you for sending this to us. the bug ID is CMPLRLLVM-43747
Here is a variation, which also fails. I post it as the first testcase runs fine with current gnu fortran, but this new one fails with gfortran as well.
module mod
implicit none
private
type, public :: t
integer :: i = 65
contains
procedure :: get
end type t
contains
pure function get(self) result(i)
integer :: i
class(t), intent(in) :: self
i = self%i
end function get
end module mod
program select_rank_tbproc
use mod
implicit none
type(t) :: x
class(t), pointer :: y
allocate(y, source=t(73))
call p(x%get()) ! fine
call p(y%get()) ! segfault
deallocate(y)
contains
subroutine p(v)
select rank (v)
rank (0)
select type (v)
type is (integer)
end select
rank default
end select
end subroutine p
end program select_rank_tbproc
Thank you! I added it to the bug report.
I just confirmed the fix for this bug is in the 2024.1.0 compiler.
