trouble with ifort-11 when compiling a program with specific options :
sade{coul} 21 : ifort -c -g -openmp -zero -fpe0 -fltconsistency sparse_matrix.f90
sparse_matrix.f90(516): (col. 11) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
sparse_matrix.f90(525): (col. 11) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
0_1855
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
in file sparse_matrix.f90, line 516, column 31
compilation aborted for sparse_matrix.f90 (code 3)
sade{coul} 22 : ifort --version
ifort (IFORT) 11.0 20090318
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
But if I compile the same program, with the same options, using ifort (IFORT) 11.0 20090131, then all is OK.
0_1855
I have reported this to the developers - the issue ID is DPD200139790. It seems to relate to naming ROW in the PRIVATE clause where ROW is a POINTER to type ROW_TYPE.
Quoting - Steve Lionel (Intel)
- is that trouble already solved in a more recent version ?
- is the object file correctly generated when the compile phase is OK (for instance in omitting the compilation option -g)?
- how to follow the issue ID you have provided?
Thank you in advance
Franois Jacq (alias lcoul or FJ depending on the forum)
The problem is not yet fixed - I will update this thread when there is news about the issue. On review, omitting -g may not help you, but you can try it. It seems more tied to the optimization level - with optimization disabled, as it is with -g, I see the error. Sometimes with optimization enabled, I don't.
This bug has been fixed in our sources. The fix is expected to be in Update 4, planned for the second half of December.
This issue is resolved in Update 4, available now.
