29427 Discussions
ICE for simple matmul expression, when checks are turned on
Balint_Aradi
Dear developers,
the current ifort (2021.1 Beta 20201112, but also the 2020.x version) generates an internal compiler error when compiling the following code:
program showbug
  implicit none
  integer, parameter :: dp = kind(1.0d0)
  real(dp) :: cellMiddle(3), boxMiddle(3), frac(3)
  real(dp) :: recVecs2p(3,3)
  frac(:) = matmul(boxMiddle - cellMiddle, recVecs2p)
end program showbug
when compiling with
ifort -check ~/bug.f90
I obtain (on x86_64.Linux)
/home/aradi/bug.f90(8): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for /home/aradi/bug.f90 (code 1)
Interestingly, if I store the result of the subtraction in a temporary variable, the code compiles. The code also compiles, if I leave away the `-check` flag.
Barbara_P_Intel
Thank you for reporting this.
I compiled your reproducer successfully with the current compiler 2021.5.0 that is part of oneAPI 2022.1 HPC Toolkit.
$ ifort -V -check showbug.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.5.0 Build 20211109_000000
Copyright (C) 1985-2021 Intel Corporation.  All rights reserved.
 Intel(R) Fortran 2021.5.0-1068
GNU ld version 2.26.1-1.fc25
$ a.out
Can you install that and recompile?
Barbara_P_Intel
$ a.out
Balint_Aradi
Thanks for the quick response! I can confirm, that with version 2021.5 the problem does not appear any more.
Barbara_P_Intel
That's GREAT!   Thanks for the reply!
