I was going to make a run with array bounds checking on in my release mode. But got an ICE (Internal Compiler Error) in one of the routines instead.
Anything I should look for? Besides sending a VERY LARGE project to premier support (who already have several ICE and other under investigation)
The single source file (and compile options) which provokes the ICE would be sufficient reproducer for your premier bug report.
Issue 665075 submitted.
I didn't mention that I have the debug configuration with full debug turned on (but probably not optimize for speed) and everything compiles there.
