ICE in latest IFX compiler
Stephen_Sutcliffe
New Contributor II
The attached module code produces an ICE using the latest IFX compiler Intel® Fortran Compiler 2023.2.0 [Intel(R) 64] on Windows 11. The source consists of a single module file taken in isolation from a large project solution. I was getting the same messages when trying to compile the full solution plus a few similar relating to other modules though not all.
I've also attached the BuildLog.htm files showing compiler options for /MP=NO.
With /MP option set to Yes an additional message is output:
1>----- Build started: Project: BugReport (IFX), Configuration: Debug x64 ------
Compiling with Intel® Fortran Compiler 2023.2.0 [Intel(R) 64]...
Bug_190123_test.f90
xfortcom: Fatal: There has been an internal compiler error (C0000005).
ifx: error #10298: problem during post processing of parallel object compilation
compilation aborted for C:\Users\steve\Dropbox\General\BugReport\Bug_190123_test.f90 (code 1)
With /MP option set to No:
Bug_190123_test.f90
Build log written to "file://C:/Users/steve/Dropbox/General/BugReport/x64/Debug/BuildLog.htm"
BugReport - 1 error(s), 0 warning(s)
Errors such as these are the main reason for me not to move over to IFX from IFORT.
Can someone at Intel please have a look into this? Any feedback would be appreciated. Hopefully it will lead to fixes, that will enefit everyone, assuming problem is not a result of errant coding on my part.
Devorah_H_Intel
This ICE is fixed in the next compiler release. I just tested it with the latest 2024 and there is no ICE with IFX 2024, while there is with IFX 2023.2
Thank you for reporting this.
Devorah_H_Intel
