29650 Discussions
Bad padding with NUL, character array constructor in initialization of derived type
Harald1
New Contributor II
The following code shows an issue with character array constructor in initialization of a derived type:
program p
  implicit none
  type t
     character(3), allocatable :: c(:)
  end type t
  type(t) :: z1, z2
  z1% c =    [ character(1) :: 'b', '*']
  z2    = t( [ character(1) :: 'b', '*'] ) ! bad padding with NUL chars
  print *, ">", z1%c, "<"
  print *, ">", z2%c, "<"
end
 With ifort/ifx I get:
 % ifort ifort-char-array-ctor.f90 -check all,nouninit && ./a.out | cat -ev
 >b  *  <$
 >b*^@^@^@^@<$
Expected: lines 2 and 3 should be identical.
Apparently the constructor in line 8 that initializes z2 lacks a proper typespec to convert from character(1) to character(3).
Works as expected with NAG, gfortran, and some other compiler.
Ron_Green
The plot thickens.
I tested with an early build of the upcoming 2024.0.  It's better, but still not correct.
ifx -V -what ifort-char-array-ctor.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build xxxxxxxx
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
Intel(R) Fortran 24.0-1238.2
GNU ld version 2.39-9.fc38
rwgreen@orcsle153:~/quad$ ./a.out
 >b  *  <
 >b*<
rwgreen@orcsle153:~/quad$ gfortran ifort-char-array-ctor.f90
 >b  *  <
 >b  *  <
We'll open a bug report for this.
Igor_V_Intel
This bug is escalated to the development team to be fixed.
