ICE on procedure pointer
Arjen_Markus
the program below gives an internal compiler error when compiled with Ifort 11.1 on Windows (build: 20091130). I know it contains a syntax error, but the error message is not clear ;). If I leave out the
"pointer" attribute on zf, a different message is generated which is not very clear either - it claims the name
zf is already used as an external procedure name.
If I correct the syntax error (...%zfunc => zf) it compiles correctly.
Arjen
! mechanism.f90 --
! Module for registering the implementations of failure mechanisms
module mechanism_data
implicit none
type mechanism
character(len=40) :: name ! Name of the mechanism
character(len=40), dimension(:), pointer :: param ! Names of the relevant parameters
procedure(zfunc_evaluation), pointer, nopass :: zfunc ! Pointer to the zfunc subroutine
end type
abstract interface
subroutine zfunc_evaluation( param_value, zvalue )
real, dimension(:), intent(in) :: param_value
real, intent(in) :: zvalue
end subroutine
end interface
end module mechanism_data
module mechanism_general
use mechanism_data
implicit none
type(mechanism), dimension(100) :: registered_mechanism ! Array of mechanisms
integer :: no_registered = 0 ! Number registered
contains
subroutine register_mechanism( name, param, zf )
character(len=*), intent(in) :: name
character(len=*), dimension(:), intent(in) :: param
procedure(), pointer :: zf
integer :: i
if ( no_registered < size(registered_mechanism) ) then
i = no_registered + 1
registered_mechanism(i)%name = name
allocate( registered_mechanism(i)%param(size(param)) )
registered_mechanism(i)%param = param
registered_mechanism(i)%zfunc = zf
else
write(*,*) 'Too many mechanisms! Program stopped'
endif
end subroutine register_mechanism
end module mechanism_general
mecej4
The current release for Windows is 11.1.065 (20 April 2010). The ICE that you report may have been fixed in the current release for Windows.
If the compiler experienced an internal error, the implication of the terminal statement that it made could not be more clear: "I am so thoroughly confused that I have to stop!".
With your code, the current release (11.1.072) of the Linux version of the compiler gives the error message
[bash] Intel Fortran 11.1-2739
markus.f90(34): error #8321: An EXTERNAL procedure name must not appear as the right side expression in an assignment statement. [ZF]
[/bash]
After making the modification of leaving out the pointer attribute for zf, the additional error message is
[bash]The POINTER attribute must be specified for a procedure component definition.
procedure(zfunc_evaluation), nopass :: zfunc ! Pointer to the zfunc subroutine
^[/bash]
The messages appear to be worded reasonably.
You may find this recent thread on the Linux/Mac Fortran forum to be of some relevance:
http://software.intel.com/en-us/forums/showthread.php?t=76793&o=d&s=lr
Arjen_Markus
Indeed, those messages are understandable. I will have to verify with my sysadmins if they have the latest
version for me ;).
Arjen
