29386 Discussions
ICE when associated is called for a dummy (function) procedure pointer
Cross__Mat
I'm using
$ uname -a
Linux stonehenge 3.3.0-4.fc16.x86_64 #1 SMP Tue Mar 20 18:05:40 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
$ ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1 Build 20120212
and have
$ cat pp.f90
[fortran]module m0 abstract interface function f() end function f end interface interface subroutine s(ff) import f procedure(f), pointer, intent(in) :: ff end subroutine s end interface end module m0 use m0, only : f, s procedure(f) :: f2 procedure(f), pointer :: pp pp => f2 call s(pp) end subroutine s(ff) use m0, only : f procedure(f), pointer, intent(in) :: ff procedure(f) :: f2 print *, associated(ff,f2) end subroutine s function f2() end function f2 [/fortran]
which gives
$ ifort pp.f90
pp.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for pp.f90 (code 1)
The file compiles OK if f, ff and f2 are subroutines.
Thanks for the nice test case. I can reproduce this and have escalated it as issue DPD200180573.
This problem has been fixed for a release later this year.
