ICE when using structure constructors for function pointer components
Sean_S_2
Here is some example code:
program test_function_constructor
implicit none
abstract interface
   integer function get_int()
   end function get_int
end interface
type :: foo
   procedure(get_int), nopass, pointer :: get => null()
end type foo
type(foo) :: bar
bar = foo(foo_int) ! Causes ICE
bar%get => foo_int ! OK (my current workaround)
contains
  integer function foo_int()
    foo_int = 0
  end function foo_int
end program test_function_constructor
There was a previous bug about a similar issue here:
http://software.intel.com/en-us/forums/topic/270982
That bug was fixed and the test case there still is OK. This new bug triggers in different circumstances. Namely:
  1. The type being constructed must be declared in the same module (or as above, program block) as the code that uses the constructor.
  2. The procedure pointer must point to a function, not a subroutine.
If either of those conditions isn't met, the code compiles fine. Unlike the earlier issue, it doesn't matter in this case if you default-initialize the function pointer to null().
Kevin_D_Intel
Thank you for reporting this error and for the convenient test case. I reproduced the error and reported it to Developers (see internal tracking id below). I will keep the post updated on the status of a fix as I learn it.
(Internal tracking id: DPD200255193)
(Resolution Update on 11/17/2014): This defect is fixed in the Intel® Parallel Studio XE 2015 Update 1 release (2015.0.133 - Linux)
Kevin_D_Intel
This defect is fixed in the Intel® Parallel Studio XE 2015 Update 1 release (Version 15.0.1.133 Build 20141023 - Linux) now available from our Intel® Registration Center.
