- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Test case attached, here is how to run it, and the output I get with ifort version 12.1.0 (20110811):
The ICE is averted if -heap-arrays is removed or if -O3 is changed to -O2.
I would appreciate a workaround that doesn't involve switching -O3 off, if you find one.
EDIT: the ICE does not occur with ifort 12.0.5 (20110719)
[bash]$ ls 111017_ice.zip 111017_ice.zip $ unzip 111017_ice.zip Archive: 111017_ice.zip creating: fftw3.3/ creating: src/ inflating: test_ifort_ice.txt inflating: fftw3.3/fftw33.f90 inflating: fftw3.3/fftw3.f03 inflating: src/image_fft.f90 inflating: src/runtime_parameters.f90 inflating: src/runtime_parameters.f90~ inflating: src/image_base.f90 inflating: src/image_looping.f90 inflating: src/image.f90 $ source test_ifort_ice.txt rm: No match. : catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for src/image.f90 (code 1) [/bash]
Ссылка скопирована
7 Ответы
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
OK, I'll get a report started and see if I can find a workaround.
ron
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Ron,
Did you manage to reproduce this?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
sorry for the delay, I have been at a conference and traveling.
Yes, I can reproduce on the latest compilers.
The error is when it compiles AMPL_FROM_HALF_TO_FULL_OLD in image.f90. I am trying to simplify it some, but it seems it needs most of the context/statements in this to reproduce.
You can compile image.f90 at -O2 to avoid. The O3 loop transforms are what is crashing. The other files can all be compiled with -O3 -heap-arrays, and only image.f90 at -O2 -heap-arrays would be a work around.
Still working to trim this down, should have more info later today.
ron
ron
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
OK, I found it and have a new version of image.f90 that is functionally equivalent.
As I said, the culprit is a compiler bug compiling AMPL_FROM_HALF_TO_FULL_OLD in image.f90.
This code, near the end, has 2 IF ELSE ENDIF blocks with the same condition.
Thus, at O3 the compiler is trying to fuse the 2 IF blocks into 1 IF block.
You can compare my code with your original.
I have attached a revised image.f90 below that is functionally equivalent. I manually merged the 2 identical IF blocks. This compiles at -O3 -heap-arrays.
Also look at my reproducer below and you'll see the identical IF conditional in 2 IF blocks back-to-back.
For reproducing the bug for the bug report, I used the code below which removed all USE dependences, removed the module, etc. Again, the bug is triggered when O3 tries to merge the 2 IF blocks.
[bash] SUBROUTINE AMPL_FROM_HALF_TO_FULL_OLD(IMG) implicit none TYPE IMAGE INTEGER :: DIM(3) = (/1,1,1/) REAL, POINTER :: RVALUE(:,:,:) END TYPE IMAGE TYPE(IMAGE), INTENT(INOUT) :: IMG TYPE(IMAGE) :: TMP INTEGER :: I REAL, ALLOCATABLE :: RTEMP(:) ! Prepare the temporary image TMP = IMG IMG%RVALUE = 0.0 ! First the first Y-Z plane needs to be flipped. IF (IMG%DIM(3) .GT. 1) THEN IMG%RVALUE(1,1,1:IMG%DIM(3)) = 0.0 ENDIF IF (IMG%DIM(3) .GT. 1) THEN DO I=IMG%DIM(1)/2+2,IMG%DIM(1) RTEMP(1:IMG%DIM(2)-1) = RTEMP(IMG%DIM(2)-1:1:-1) ! reverse order within RTEMP IMG%RVALUE(IMG%DIM(1)-I+2,2:IMG%DIM(2),1) = RTEMP(1:IMG%DIM(2)-1) ENDDO ENDIF END SUBROUTINE AMPL_FROM_HALF_TO_FULL_OLD [/bash]
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Ron,
Nice catch & many thanks for the workaround.
Alexis
Alexis
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You did most of the work getting the right code to me with a great description of how to build. the rest was just my grunt work :)
The bug report is DPD200175015
we'll keep you posted when a fix is available.
ron
ron
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
This bug is fixed in the recent 12.1 compilers released after February 2012.
closing this issue
ron
closing this issue
ron
Ответить
Параметры темы
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
