The attached code produces and ICE with ifort 13.0.0.079, while compiling smoothly with 12.1.0.079.
ifort -c test.f90
test.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for test.f90 (code 1)
ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.0.079 Build 20120731
module mod_a
implicit none
integer :: n
abstract interface
pure function i_f() result(y)
import :: n
implicit none
real :: y(n)
end function i_f
end interface
procedure(i_f), pointer :: f => null()
end module mod_a
Thank you for the nice reproducer. It appears the error occurs related to “import n”. The code compiles when “n” is a dummy argument or when “n” is made accessible in the host scope via USE from a separate module but I do not know if either is a viable work around for you or not. I reported this to Development (internal tracing id below) for further analysis and will update once I learn more.
(Internal tracking id: DPD200238143)
(Resolution Update on 11/27/2013): This defect is fixed in the Intel Fortran Composer XE 2013 SP1 Initial Release (2013.1.0.080 - Linux)
Pardon the delayed update. I confirmed this internal error was fixed in the Composer XE 2013 SP1 Initial Release (w/ 14.0 compiler) (2013.1.0.080 - Linux) in September.
