- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
With a production code (https://fabm.net) that is regularly tested with many compilers including ifort, I get the following error with the latest ifx:
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x146f4ea]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10f84dd]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x1156992]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x1156ac0]
/lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f5d75b20090]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10c370b]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10c37e2]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10c354a]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10a9fe8]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x10552ec]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0x11fb612]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f5d75b01083]
/home/jbr/intel/compiler/2022.1.0/linux/bin-llvm/xfortcom[0xe701e9]
/tmp/ifxBWcBH5.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for /home/jbr/Temp/fabm/src/fabm.F90 (code 3)
To reproduce this:
git clone https://github.com/fabm-model/fabm.git
mkdir build
cd build
cmake ../fabm -DCMAKE_Fortran_COMPILER=ifx
make
Is there anything further I can do to identify the line or lines causing the issue?
Jorn
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I will be happy to file a bug report. Can you attach just the file(s) required to produce the ICE (internal compiler error)? If fabfm.F90 uses modules or any include files, attach the source for those, too.
Thank you!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I downloaded the app and am working on isolating the ICE, Internal Compiler Error. I thought I would let you know, so we're both not working on it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I filed a bug, CMPLRLLVM-39826.
You can use ifort as the workaround. No ICE there.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks! We ourselves and many of our users do use ifort regularly; it is included in our automated testing too (https://github.com/fabm-model/fabm/actions/runs/2904973615) It has always worked fine (versions dating back to at least since 2012). However, since ifx is presumably meant to replace ifort in some point in the the future (?), it would be great if we could get it to work with our code too. Hopefully the bug report will lead to that.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Do you know that you can mix and match .o files and .mod files between ifort and ifx? That will allow you to continue testing ifx.
There is also this Porting Guide.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Please check out the latest release of ifx. The compiler no longer ICEs.
It's part of the oneAPI HPC Toolkit 2023.2 that was released last week.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks very much! I can confirm that this code compiles fine with the latest ifx.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
