29392 Discussions
ICE with merge() and procedure pointer
Harald1
New Contributor II
all tested versions of ifort up to 2021.7.0 ICE on the following:
program p
  implicit none
  procedure(real), pointer :: a => NULL()
  print *, merge (a, a, .true.)
! call foo (merge(a, a, .true.))
end
I get:
ifort-merge.f90(4): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ifort-merge.f90 (code 1)
Harald
Barbara_P_Intel
I just filed a bug report on this, CMPLRIL0-34949. I'll post when a fix is available.
Barbara_P_Intel
Barbara_P_Intel
This ICE is fixed for both ifort and ifx. Now you'll see a real error message!
Check out the new versions of the compilers available in oneAPI HPC Toolkit 2023.1. This version was just released this week.
Harald1
New Contributor II
Yes, the ICE is gone.
I was surprised at first by the error message that starts with "catastrophic error: ..." and had to look twice to confirm that it is no longer that catastrophic ....
