29653 Discussions
ICE with nested structure constructors
IanH
The following ICE's 12.0.4 (with /warn:all /check:all /standard-semantics):
[fortran]PROGRAM poly_constructor
  IMPLICIT NONE
  TYPE :: parent
    INTEGER :: component
  END TYPE parent
  TYPE wrapper
    CLASS(parent), ALLOCATABLE :: item
  END TYPE wrapper
  TYPE(wrapper) :: scalar
  scalar = wrapper(parent(2))
END PROGRAM poly_constructor
[/fortran]
If you delete the component of parent and remove the argument 2 from the structure constructor, the form of the ICE is a bit different. Then (in addition, not independently) you can make the component non-polymorphic too, and things still go pear shaped.
(Apologies if it's already been reported, some of these examples all blur into each other after a while.)
Thanks - I don't recall seeing these before. Escalated as issue ID DPD200169923.
These issues will be fixed in a future version of the compiler.
