29487 Discussions
ICE with procedure ponter and procedure interface
MR
Hi, I noticed that the attached code gives an intrnal compiler error when using ifort 13.0 (the same code works with a previous version). More precisely: ifort -c ice.f90 ice.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for ice.f90 (code 1) ifort -V Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0 Build 20121010 (Version 12.1 Build 20120212 works fine) Marco module ice implicit none public :: i_f, f_p private integer, protected :: n abstract interface pure function i_f(x) result(y) import :: n implicit none real, intent(in) :: x real :: y(n) end function i_f end interface procedure(i_f), pointer :: f_p => null() end module ice
Thanks - I have escalated this as issue DPD200240502 and will let you know of any progress.
MR
Steve, OK, thank you.
Marco
The internal compiler error is fixed for a release later this year. A workaround would be to remove f_p from the PUBLIC statement and then give f_p the PUBLIC attribute explicitly, but the Update 2 compiler doesn't like that. Update 3 should allow that workaround.
