ICE
Walt_Brainerd
I stopped getting e-mail with these posts on Dec 2, so haven't kept track
of what is going on. But here is an ICE--maybe submitted previously.
ifort -c int*
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.
0.1.148 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
intel_bug.f90(32): error #5276: Unbalanced parentheses
   x = line_type(0.0, 1.0, 0.0, 1.0))
intel_bug.f90(32): error #5082: Syntax error, found ')' when expecting one of: <END-OF-STATEMENT> ;
intel_bug.f90(32): error #8726: There may be at most one type parameter spec corresponding to each p
arameter of the type.   [0.0]
fortcom: Fatal: There has been an internal compiler error (C0000005).
compilation aborted for intel_bug.f90 (code 1)
module m
   implicit none
   private
   type, public :: line_type
      real :: x1, x2, y1, y2
   contains
      procedure, public :: length
   end type line_type
contains
function length(ab) result(length_result)
   class(line_type), intent(in) :: ab
   real :: length_result
   length_result = 1.1
end function length
end module m
program p
   use m
   implicit none
   class(line_type), allocatable :: x
! Note extra paren at end
   print *, x%length()
end program p
Thanks, Walt, we'll take a look, but this sounds familiar.
FortranFan
I can reproduce the ICE using Intel(R) Visual Fortran Compiler XE 15.0.1.148.
The offending line, when corrected for syntax, corresponds to an intrinsic assignment involving a polymorphic, allocatable variable, a Fortran 2008 feature, which is not yet supported by Intel Fortran.
Just got a Windows 8.1 laptop over the holidays and on this machine, the program when modified to not use a polymorphic variable for x (i.e., TYPE(line_type), ALLOCATABLE :: x) gives an "access violation" error upon execution at the assignment statement.  The same code runs fine on the Windows 7 PC that I normally use.  I just started on Windows 8.1 with this laptop (I hate it already!) and this is my first attempt at using Intel Fortran on it, so not sure if I have everything correct.  I wonder if someone can try to reproduce this attempt and post the response.
mecej4
With the 15.0.1.148 compiler, the ICE (access violation) occurs only with the 64 bit compiler on Windows 8.1.
One of the first adds-on you (FortranFan) should consider when starting to use Win 8.x is  Classic Start Menu (or something similar) to avoid the frustrations of the 8.1 tile interface.
dboggs
I have been using Win 8.1 for a few months now--always in the desktop (classic start) mode, and so far I find it no different from my previous Win 7. Except, that is, for the problem of unauthorized file access that I reported on another thread (the consensus is that was a timing problem caused by Windows delay in releasing a file handle, and happened because my 8.1 machine is "too fast").
But admittedly, my use of Fortran is pretty elementary, and I don't dabble in things like allocatable polymorphic variables.
FortranFan
FortranFan wrote:
Just got a Windows 8.1 laptop over the holidays and on this machine, the program when modified to not use a polymorphic variable for x (i.e., TYPE(line_type), ALLOCATABLE :: x) gives an "access violation" error upon execution at the assignment statement.  ...  I wonder if someone can try to reproduce this attempt and post the response.
False alarm: once I added /standard-semantics compiler option to the Windows 8.1 project, the program executed without any issues.
Re: Windows 8.1, thanks mecej4 and dboggs for the classic Start menu add-on suggestion.
While I did remember another issue with unbalanced parentheses triggering an ICE, this case is different. Escalated as issue DPD200364932.
This problem has been fixed for a release later this year.
