IFLangServicePackage
ovz
  When compiling my mixed C++/Fortran Visual Studio 2012 solution from command line  using devenv.com I can see the following in the output before actual build process starts
Package 'IFLangServicePackage' failed to load.
Is there something I can do to get rid of these messages?
martymike
No, as I said, we haven't tried that. I could set up a test to see it solves the problem, and I probably will. Fixing it in production is a little trickier because we don't run devenv from a batch file but from a python script. I was hoping to find out what it means and what the consequences are.
I just did an experiment opening a plain command prompt (not one of the Fortran build environments) and running devenv.exe from VS2013. It loaded fine and Fortran projects worked. All I can think of is that there's something extra in your PATH that is causing problems.
