IFORT and IFX Compiler Bug
Horne__Steven
The following code produces unexpected output for type2%intValue. This seems to be the simplest form of the code that produces the issue (the type requires an allocatable class field, and the issue requires an assignment to an "intent(out)" variable). I've tested this in IFX 2024.0.2, 2024.2.1, and 2025.0.0, as well as IFORT 2021.11.0 and 2021.12.0. Code posted below and is included in the attached file. gfortran produces the expected output.
module testMod
    type DummyType
    end type DummyType
    type ParentType
        class(DummyType), allocatable :: templateObject
        integer :: intValue = 0
    end type ParentType
contains
    subroutine RunTest(type1)
        type(ParentType), intent(out) :: type1
        type(ParentType) :: type2
        type1%intValue = 1
        type2 = type1
        print *, 'Type1 intValue=',type1%intValue
        print *, 'Type2 intValue=',type2%intValue
    end subroutine RunTest
end module testMod
program TestDerivedTypeAssignment
    use testMod, only : ParentType, RunTest
    type(ParentType) :: type1
    call RunTest(type1)
end program TestDerivedTypeAssignment
Labels (2)
Horne__Steven
Note: this also occurs when a variable is assigned to the result of a function (e.g. with a constructor).
Devorah_H_Intel
Thank you for your report. I was able to reproduce the incorrect value. I have escalated this issue to compiler engineering.
Devorah_H_Intel
The fix will be available in the 2025.1 ifx release.
