29274 Discussions
IFORT debug and release builds hang
AONym
New Contributor II
Intel Fortran Compiler w_oneAPI_2023.0.0.25839; Visual Studio 2022 17.5.3
When I build or rebuild my C++ / Fortran project, during the compilation process, VS hangs. I'm using Intel Fortran Compiler Classic 2021.8.0.
By "hangs" I mean one of Microsoft Visual Studio 2022 threads is using 6-12% of the CPU, and VS shows as "not responding" in Task Manager.
After each hang, which lasts 2-5 minutes VS seems to proceed to the next step in the build process, eventually finishing. The resulting executable behaves normally.
The hangs are more frequent with release builds (when IFORT is optimizing code) than with debug builds. I cannot determine where in the process VS is, because the output window is not being updated during the hangs.
What could be causing these annoying hangs, and how do I get rid of them?
jimdempseyatthecove
A few things come to mind.
1) Your Anti-Virus is scanning the output files (though 2-5 minutes seem extreme). This can be fixed by excluding your output folder(s) from scanning.
2) You are compiling Fortran source file created by a program. These tend to have very large numbers of continuation lines with expressions spanning many lines.
3) Interprocedural Optimizations are being too agressive. Try disabling IPO (or selecting single file IPO instead of multi-file IPO).
Jim Dempsey
Steve_Lionel
Are you using a local disk or a network share? Does it do this when building C++ code?
AONym
New Contributor II
Local disk. It doesn't do this when building C++.
Steve_Lionel
Is there one particular source file that triggers this?
