IFPOSIX
Eldhuset__Knut
I have start problems with IFPOSIX calls. In the small program below I
have set iopenflag=0 and imode=0.
How do Iset these parameters. Ihave indicated whatI want to do in the commented lines
iopenflag=IPXFCONST(O_RDONLY) ????.
If I try the program below I get ierror_2=22 and nread=183
Hope you can complete the program
Regards Knut Eldhuset
PROGRAM read_posix
USE IFPOSIX
character*200 path
integer*2 buf(2000)
character buf2(4000)
equivalence (buf,buf2)
path="C:\KE_FILES\Radarsat 2\Flevoland_DK405_FQ9_20080402_171638_H
+H_VV_HV_VH_SLC\imagery_vv_magn"
ilen_pathn=90
! iopenflag=IPXFCONST(O_RDONLY) ????
! imode=IPXFCONST(O_BINARY) ????
iopenflag=0
imode=0
call pxfopen(path,ilen_pathn, iopenflag , imode,ifildes,
+ierror_1)
write(*,*)'ierror_1:',ierror_1
ioffset=0
iwhence=0
call pxffseek(ifildes,ioffset,iwhence,ierror_2)
nbytes=2000
write(*,*)'ierror_2:',ierror_2
call pxfread(ifildes,buf2,nbytes,nread,ierror_3)
write(*,*)'ierror_3,nread',ierror_3,nread
write(*,*)buf(16:18),buf(147:148)
end
TimP
Path names with spaces are tricky. You would likely need quote marks inside the string-defining quote marks which don't go into the compiled string. Try at least to set up the string so it works on command line, e.g. with DIR. Avoid taking chances with line continuation in mid string. You could define 2 constant strings and concatenate them in Fortran by //.
