IFWINTY and NULL Pointers
andrew_4619
        bret =  CreateProcess (NULL_CHARACTER,gnam, &         ! Application Name, cmdline
                    NULL_SECURITY_ATTRIBUTES, &
                    TRUE, &                                   ! InheritHandles
                    0, &                                      ! CreationFlags CREATE_NEW_CONSOLE
                    NULL, &                                   ! Environment variables
                    NULL_CHARACTER, &                         ! Current directory
                    StartupInfo, &
                    ProcessInfo)                              ! process id etc returned
With  2017 update 1 and  /check:pointer set all the NULL_xxx args give a run time error. In IFWINTY they are are declared as pointers to the specifics types. Shouldn't those be initialised with the NULL() instrinsic? I am slightly confused as I think in my mind that compiled OK with 16 and 17 original but I would need to make a test case as the full source will only compile in the latest compiler because of bug fixes only in that one.
jimdempseyatthecove
There was a post (within 2-3 weeks) where it was found that the Windows interface declarations were in error (Steve may recall this). Perhaps your issue is related. This was 32-bit vs 64-bit oversight.
Jim Dempsey
Interesting. This would have failed in 16.0 as well. Just use NULL for these arguments.  Initializing them to NULL() would not change the behavior. Some time ago we change the interface for CreateProcess to take the arguments by reference but with IGNORE_LOC and ALLOW_NULL. This allows you to use a constant zero as an argument even though the type doesn't match. But when you pass a pointer, the compiler thinks you're accessing the value and gives the "null pointer" error if you have enabled pointer checking. I don't think it should here, and I believe I already reported this as an issue, but if not I will do so.
andrew_4619
Easy enough to fix in several different ways but:
        bret =  CreateProcess ( &
                   NULL(NULL_CHARACTER),gnam, &         ! Application Name, cmdline
                   NULL(NULL_SECURITY_ATTRIBUTES), &
                   NULL0, &                             ! Environment variables
                   NULL(NULL_CHARACTER), &              ! Current directory
                   StartupInfo, &                       ! populated attributes T_STARTUPINFO strucure
Works with no problem as we are passing a pointer of the correct type that is initialised to zero. I think the compiler is complaining about  the pointers being uninitialised. In Iwfinty we have:
type(T_SECURITY_ATTRIBUTES), pointer :: null_security_attributes
To to my mind that should be:
type(T_SECURITY_ATTRIBUTES), pointer :: null_security_attributes = null()
What I don't understand is what has changed.......
My experiments show that nothing has changed - I can reproduce the problem going back to 12.0. Initializing the pointer to NULL() didn't change the behavior for me. At most I can theorize that if the pointer was not initialized, it might have some non-zero value that bypassed the check, but then the API call would almost certainly fail.
I have requested, in issue DPD200416141, that the compiler skip doing pointer checking for a dummy argument that has the ALLOW_NULL attribute, as most (but perhaps not all) of the relevant API declarations do. These APIs allow you to just put in NULL and that is the preferred solution. If you find APIs where this doesn't work, then I'd recommend  turning off pointer checking (it is not the default, even in a Debug configuration).
jimdempseyatthecove
>>I have requested, in issue DPD200416141, that the compiler skip doing pointer checking for a dummy argument that has the ALLOW_NULL attribute.
Wouldn't it be better to have the ALLOW_NULL attributed argument to permit NULL .OR. valid pointer?
Jim Dempsey
It already allows NULL or a valid pointer. The change would be to not do a null-pointer check for such arguments.
