29430 Discussions
IFX Fortran compiler not passing values correctly.
Grant_Smith
I am using a C++ API function called from a Fortran routine.
The call code is
SIDOK = SIDPUTVOL(%VAL(J2),%VAL(D2),%VAL(VCLASS),%VAL(TVOL))
the C++ code is
VARIANT_BOOL __stdcall SIDPUTVOL(long origin, long dest, long vclass, float volume)
when I use IFORT 'TVOL' is passed to 'volume' correctly
When i use IFX 'volume' takes either zero or e-37
Tvol and volume are both 4 byte real. the integer values are passing correctly.
Can anyone help?
jimdempseyatthecove
Check the reference manual for C Interoperability.
You should declare an interface to SIDPUTVOL something like:
interface
  function SIDPUTVOL(J2, D2, VCLASS, TVOL) bind(C,name='SIDPUTVOL') result(ret)
    use, intrinsic :: ISO_C_BINDING
    implicit none
    integer(kind=c_long), value :: J2, D2, VCLASS
    real(kind=c_float), value :: TVOL
    logical(kind=c_bool) :: ret ! ** guessing at this
  end function SIDPUTVOL
end interface
Place the interface in a module and use that module where you make calls to SIDPUTVOL
Also, in your C++ code add a prototype
extern "C"
VARIANT_BOOL SIDPUTVOL(long origin, long dest, long vclass, float volume);
And make the actual declaration match.
Jim Dempsey
jimdempseyatthecove
interface
    implicit none
end interface
extern "C"
Jim Dempsey
