29269 Discussions
IFX complex skew-conjugate optimization with complex part designators
DataScientist
Valued Contributor I
Consider the following two code snippets that perform the same task (of skew-conjugation of complex value), but the IFX (and ifort) compiler(s) emit slightly different assembly instructions for the two:
```fortran
contains
function skewconjg(x) result(res)
complex, intent(in) :: x
complex :: res
res = cmplx(-real(x), aimag(x), kind(res))
end function
end
and
```fortran
contains
complex :: res
res%re = -x%re; res%im = x%im
end function
end
The (different parts of the) corresponding assembly codes are respectively:
```asm
movss xmm1, dword ptr [rcx + 4]
movss xmm0, dword ptr [rcx]
movaps xmm2, xmmword ptr [rip + .LCPI1_0]
pxor xmm0, xmm2
movss dword ptr [rax + 4], xmm1
movss dword ptr [rax], xmm0
and
```asm
movaps xmm1, xmmword ptr [rip + .LCPI1_0]
pxor xmm0, xmm1
movss xmm0, dword ptr [rcx + 4]
movss dword ptr [rax + 4], xmm0
The second code (associated with complex part designators) seems to do some redundant work here. Specifically, `movss xmm0,[rcx]` right before loading `[rcx+4]` seems to be redundant; it’s overwritten immediately and has no effect. Is this a missed compiler optimization, or are there reasons for such a difference between the two codes?
Notably, gfortran generates the same assembly for both codes.
Here are compiler explorer links for testing:
https://godbolt.org/z/nesWEfWzj
and
https://godbolt.org/z/1ax3q8bTs
