29607 Discussions
IFX does not create pdb for static library project
Mark_Lewy
Valued Contributor I
Consider the attached solution, created in VS2022 (17.7.5) using the static library template.  If you build the Debug configuration no pdb file gets created in x64\Debug, but if you change the compiler to IFORT it will create a pdb file.
Mark_Lewy
OneAPI 2024.0, BTW
Devorah_H_Intel
The issue is that ifx does not allow you to name the pdb file  (regardless of whether /Fd or /pdbfile is used). I have escalated this to Compiler engineering.
jimdempseyatthecove
As a work around, create a post-build event (batch file) to rename the default .pdb file to the desired name.
Jim Dempsey
