29487 Discussions
IFX power operator results changes when exponent is changed from constant to variable
NasarAli
IFORT does not have this issue.
IFX power operator result differs when exponent is:
1. integer constant
2. integer variable or real constant
10.02**4 = 10080.24121
(p=4) 10.02**p = 10080.24219
NasarAli
For now, I changed the floating-point model to /fp:strict for IFX.
mecej4
Single-precision reals have seven significant decimal digits (23+1 bits in binary). You are looking at the ninth significant digit, and the apparent differences are artifacts of the output format conversion.
If the difference bothers you, use an appropriate format specification and print no more than seven significant digits.
NasarAli
The double-precision real also have this issue. This code given here is just an example. The actual equations are very complex, and this issue causes a significant difference in final value.
jimdempseyatthecove
Please note, 10.02**4 is a single precision expression. 10.02_8**4 is a double precision expression.
Also, 10.02**4.0, although you can see this as an integer power, the compiler may generate code as if this were non-integer power.
Note, if your code is sensitive to least significant bits in the expression, you can promote the expression to larger precision. If your variables are single precision then promote the components and expression to double precision (then convert back to single precision)
If your variables are double precision, promote to quad precision (real(16)).
Yes, this is a tradeoff between speed and precision.
Jim Dempsey
JohnNichols
Honored Contributor I
10080.240320160
Actual answer from HP35S and EXCEL, I would tend to believe them, first.
NasarAli
