29342 Discussions
Locating the source file and line for a runtime error
Jon_D
New Contributor II
I am using Intel Fortran 2024.0 with VS 2022. Previous versions of the compiler listed the source file and line number where a runtime error occurred when the program was compiled in Debug mode. With this version of the compiler Routine, Line and Source are all listed as Unknown.  This is the case for both ifort and ifx. Is there a compiler setting that will show this information?
Thank you.
Jon
Jon_D
New Contributor II
It turns out linker setting -incremental was set to "default" in my project. Following the settings in your example, I changed it to NO and I am now able to see the proper information. Thank you, Steve.
Steve_Lionel
/traceback  It is the default in a debug configuration, but not in a release configuration. It's under Fortran > RunTime.
Jon_D
New Contributor II
Thank you, Steve. /traceback is on but I am still not getting the source file/line number information.
Steve_Lionel
Please provide a short example. I tried this:
D:\Projects>type t.f90
implicit none
integer :: a(5) = [1,2,3,4,5]
integer :: i
do i=1,10
print *, a(i)
end do
end
D:\Projects>ifx /traceback /check:bounds t.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.39.33523.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-debug
-pdb:t.pdb
-subsystem:console
-incremental:no
t.obj
D:\Projects>t.exe
           1
           2
           3
           4
           5
forrtl: severe (408): fort: (10): Subscript #1 of the array A has value 6 which is greater than the upper bound of 5
Image              PC                Routine            Line        Source
t.exe              00007FF6E92C1182  _UNNAMED_MAIN$$             5  t.f90
t.exe              00007FF6E92CA1CB  Unknown               Unknown  Unknown
t.exe              00007FF6E9326734  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFD8354257D  Unknown               Unknown  Unknown
ntdll.dll          00007FFD8472AA48  Unknown               Unknown  Unknown
Jon_D
New Contributor II
Steve_Lionel
Good to know. The default when a Fortran project is created is No for this setting.
