29649 Discussions
IFX with /O2 processes some bit operations incorrectly
mecej4
I ran the current version of IFX (Version 2024.0.2 Build 20231213) on Marsaglia's 2009 SuperKiss32 RNG test program. With other compilers and with ifx /Od or ifort /O2 or ifort /Od, the output is
S:\ALGO\packmol\src>superkiss32
 Does x = 1809478889 ?
      x = 1809478889
With ifx /O2, the test fails, with the output
      x = 1410402086
 Now, the test program generates a billion random integers before printing out the expected and computed values of the billionth random integer, so it is not easy to investigate the error with Marsaglia's original program, but here is a short reproducer that I extracted from it.
program ifxbits
   implicit none
   integer i, q(2), carry, h, z
   q = [1713231091, 1290478956]
   carry =       362
   do i = 1,2
      h = iand(carry, 1)
      z = ishft(ishft(q(i),9), -1) + &
          ishft(ishft(q(i),7), -1) + &
          ishft(carry,         -1)         ! Integer overflow possible, to be overlooked
      print *,' Before updating carry, q(',i,'), z = ',q(i),z
      carry = ishft(q(i), -23) + ishft(q(i), -25) + ishft(z, -31)
      q(i)  = not(ishft(z, 1) + h)
      print '(4x,i2,4i12)',i,q(i),h,z,carry
   end do
end program
The expected output is
S:\ALGO\packmol\src>ifxbits
  Before updating carry, q(           1 ), z =   1713231091   625619061
     1 -1251238123           0   625619061         255
  Before updating carry, q(           2 ), z =   1290478956 -1511078017
     2 -1272811264           1 -1511078017         192
and IFX with /Od gives the same output. With /O2, however, IFX gives
     2 -1272811264           1 -1511078017         191
Note "191" is output instead of "192". From then on, as you may expect in an RNG, the errors cascade.
For the convenience of anyone who wishes to run Marsaglia's program, I attach the source file.
JohnNichols
Honored Contributor I
I finally found a good Gaussian random number generator.
Take a supersensitive accelerometer, says a ST.COM MKI version which can be read using serial port Fortran, place a small timber board in a quiet location, record the thermal vibration that will range to 3 milli-g with an accuracy of 60 micro g and then use the output to generate a set of random numbers.  The only minor issue is that thermal is not truly Gaussian, it is close but after several tens of millions of measurements it is not perfectly Gaussian.  Cost about 200 USD.
One simple way is to determine the Z score of the output.  Very useful data.
mecej4
It appears upon further examination that with /O2 IFX is able to precompute the results at compile time, so we do not see any shrl instructions in the OBJ file. This implies, unfortunately, that fixing the optimization bug in the trivial reproducer is probably not going to indicate the fixes needed for the related bugs that IFX puts into the Marsaglia test EXE.
hakostra1
New Contributor II
I ran the example with the NAG compiler, and it seems that it printed the expected "192" for every optimization level O0 to O4.
I ran the example with the GFortran compiler, and it seems that it printed "192" for optimization level O0, and "191" for level 01 to 03.
JohnNichols
I do not think this going to be an easy fix for IFX, there is something fundamentally wrong in their algorithm, it is to basic to the Fortran methods to be unfixed.
hakostra1
New Contributor II
Also, 'ifort' seems to print "192" for all optimization levels.
JohnNichols
I broke the equation down to fundamental operators - one at a time and it still give an error on dp(1) although it fixed dp(3).
We all known the true answer to all questions is 42.
Barbara_P_Intel
Thanks, @mecej4, for reporting this. I filed a bug report on the reproducer, CMPLRLLVM-55293.
I understand that it may not be a "true" reproducer, but it still prints the wrong answers. It prints the wrong answer on Linux, too.
Now to untangle superkiss32.f90 a bit.
Barbara_P_Intel
I filed a bug report, CMPLRLLVM-55306, against superkiss32.f90, too. Let's leave it to the compiler internals experts to decide if the two issues are related or not.
Barbara_P_Intel
Look for ifx 2024.2.0 for the fix for ifxbits.f90. But you'll need to use a new compiler option to get the expected answers when compiling with -O1 and above.
$ ifx -what -O1 -fno-strict-overflow ifxbits.f90
 Intel(R) Fortran 24.0-1662
$ a.out
Barbara_P_Intel
And for the superkiss32.f90 reproducer use that same new compiler option, -fno-strict-overflow.
This will be available in ifx 2024.2 that will be available mid-2024.
$ ifx -what -O1 -fno-strict-overflow superkiss32.f90
$ a.out
      x = 1809478889
Barbara_P_Intel
There's a description of -fstrict-overflow in the ifort to ifx Porting Guide that explains how the behavior of ifx differs from ifort regarding integer overflow.
