29434 Discussions
IMSL library installation question IA64 vs IA32
postaquestion
I used the example file "imslmp.f90' to validadte IMSL installation. It compiled OK but at runtime, it gave the follwoing error "The applcation of DLL C:Program FilesVNIimslfnl600IA64libimsl_dll.dll is not a valid Windows image. Please check this against your installation diskette".I installed the 32 bit version, IA32; why it complained about an error in IA64. I re-installed the 32 bit IMSL library; but it didn't solve the problem.
Check the definition of PATH to see if it includes the path to the fnl600IA64 folder. My guess is that you also installed the IA-64 IMSL and it blindly adds this path even if you're not installing on IA-64. If you do not intend to develop for IA-64 I suggest uninstalling the IMSL for IA-64.
sariyer0636
I am having the same problem. Uninstalled IA64. The problem is still there. Any suggestions?
Check PATH.
urayasu55
Check PATH.
I have the same problem. It runs fine in win32, but returns an error with NUMERICAL _LIBRARIESin x64.
I set the path
C:Program Files (x86)VNIimslfnl600IA32lib
C:Program Files (x86)VNIimslfnl600IA64lib
in Libraries directories and
C:Program Files (x86)VNIimslfnl600IA32includedll
C:Program Files (x86)VNIimslfnl600IA64includedll
in Includes list.
What is the problem?
Thank you so much for any help.
I assume that the error you get is an internal compiler error? If so, unpack the attached ZIP to the folder C:Program FilesVNIimslfnl600Intel64include That should take care of it. I'll comment that the issue you're reporting is unrelated to the rest of this thread.
