need zero / x equals zero
jim_cox
Apparently IFort thinks zero / x = NaN
Our program logic expects zero / x = zero
How do we persuade IFort - or is writing our own exception handler the only only option ?
advTHANKXance
Jimmy
DavidWhite
Valued Contributor II
Quoting - jim.cox
advTHANKXance
Jimmy
Jimmy,
Can you please supply a sample of code demonstrating this issue? 0 / x should be zero unless x is zero, when NaN is the appropriate response.
David
TimP
If you have 0./0. that produces NaN according to IEEE standard. I don't see how an exception handler is relevant. If you have an expression involving divide, and you wish to set a zero result when the numerator is zero, regardless of divisor, that should be easily accomplished by testing before divide.
jimdempseyatthecove
Even if you compile with "/assume:protect_parens" and change your line to
result =numerator * (1.0/denominator)
When denominator is NaN, the result will be NaN. When denominator = 0.0 you will either get a div 0 error or NaN for (1.0/denominator). However
result = numerator
if(result .ne. 0.0) result = result / denominator
Will produce 0.0 when numerator=0.0 regardless of value of denominator.
Jim Dempsey
TimP
result = numerator
Jim Dempsey
Depending on your detailed requirements, you might prefer Jim's suggestion (as we would have 20 years ago), or
result = MERGE(numerator,numerator/denominator,abs(numerator < TINY(numerator)))
jim_cox
Quoting - David White
Jimmy,
David
we are getting the slope of a line
when
VV(2,1) = 2.0
VV(1,1)= 2.0
QQ(2,1)=500.0
QQ(1,1)=0.0
SLOPEV(JP,I) = (VV(JP+1,I)-VV(JP,I)) / (QQ(JP+1,I)-QQ(JP,I))
= NaN
jim_cox
However
result = numerator
That is elegant code thank you Jim :)
But will it work if the denominator is zero?
Better perhaps with...
result = numerator
if(result .ne. 0.0.and.denominator.ne.0.0) result = result / denominator
Wonder how many places I have to change my code?
There are only 2060 divide statements in this one program :(
Jim
=mjc=
TimP
For what it's worth, behavior of your program may depend on whether you set /Qftz- for compilation of main program, either directly, or indirectly by /fp:source
jim_cox
Quoting - tim18
For what it's worth, behavior of your program may depend on whether you set /Qftz for compilation of main program, either directly, or indirectly by /fp:source
Thankx,
Had a quick play with this setting
But in my case that doesnt seem to make any difference
DavidWhite
Quoting - jim.cox
when
VV(2,1) = 2.0
VV(1,1)= 2.0
QQ(2,1)=500.0
QQ(1,1)=0.0
= NaN
Jim,
Assuming that JP and I are set correctly for the values you quote here, the only reason I can think that you could be getting NaN is that perhaps you are exceeding your array bounds, and accessing other memory.
David
jim_cox
Jim,
David
Both JP = 1 and I = 1
and SLOPEV is declared with
INTEGER, PARAMETER :: NP=10
COMMON/COEF/QQ(NP+1,99),VV(NP+1,99),SLOPEV(NP+1,99),NPT(99)
REAL QQ, VV, SLOPEV
Slopev is happily initialised to zero elsewhere
Bounds checking is enabled and not complaining
There is so much "weirdness" going on with this code that I figure it has to be some sort of memory issue.
And I'm ripping my hair out trying to work out what / where it is
Ah the joys of an old old old codebase...
DavidWhite
Jim,
You said "There is so much "weirdness" going on with this code that I figure it has to be some sort of memory issue."
Perhaps it is notthese arrays causing the problem, but they are being trampled on from elsewhere.
Are youusing IMPLICIT NONE and ensuringthat all variables are declared and initialized properly -- may be agood place to start -- could identify variables which are not declared in the way you think they are.
Happy hunting.
David
jim_cox
Jim,
Happy hunting.
David
The codebase is such that much of the old code was written expecting implicit typing, and often with no declaration at all.
Personally I'm fussier, and the newer code is 'better'
I'm also now compiling with warnings for undeclared, unused, unalligned and interfaces etc all on - and fixing them as I go.
The routines displaying this beghaviour are compiling without complaint
more....
I tried IMPLICIT NONE
But that stopped compilation at the line
L_DEL = GDLY(.TRUE.,.5,ANGL,AS*1000/3600.,DS*1000/3600.,R)
Where GDLY is one of our library functions
Go figure...
Thankx for your input
DavidWhite
Quoting - jim.cox
more....
Go figure...
Jim,
if you add GDLY to a type statement, I think this should be resolved.
D
jimdempseyatthecove
When numerator .ne. 0.0 and denominator .eq. 0.0 just what sort of number do you want produced?
The code I listed will produce either a div by 0 exception or a NaN. Either of which are commonly accepted results. Returning 0.0 is not (not even for 0.0/0.0). The code I produces returns 0.0 for 0.0/x where x is anyting including 0.0 and NaN. This is the behavior you asked for. Y/0.0 where Y is not 0.0 produces what in your number scheme?
Wherever your program will produce a divide by 0, you must protect that section of code. This is likely a very small set of your 2060 statements. And if the NaN's are produced in places they ought not to be produced then this is an indication of an error elsewhere in your program (i.e. something else bunged up your data).
Jim Dempsey.
portoon
Quoting - jim.cox
advTHANKXance
Jimmy
I was concerning for this issue, always.
When I use following code, I got a good results.
It's idea came from tim18 andJim Dempsey.
Thanks tim18 and Jim Dempsey
Whatever a, b it's result seems to be reasonable.
a=0.0, huge, tiny, -huge, -tiny; b=0.0, huge, tiny, -huge, -tiny...etc.
____________________________________________________________
implicit none
real*8 :: a, b, c
a = 0.0d0 ! 0.0d0, tiny(a), huge(a)...
b = 0.0d0 ! 0.0d0, tiny(b), huge(b)...
c = merge( a ,a/b,dabs(a)< tiny(a))
c = merge(dsign(huge(c),c),c ,dabs(c)>huge(c))
write(*,*) a/b, c
stop
end
portoon
Jim,
D
It's idea came from tim18 and Jim Dempsey.
If a or b is not NaN, it's result seems to be reasonable.
a=0.0, huge, tiny; b=0.0, huge, tiny...etc.
implicit none
real*8 :: a, b, c
write(*,*) a/b, c
stop
end
jimdempseyatthecove
Jim,
I forgot to mention that in both my suggestion and in David's (even if merge is inlined) is that compiler optimizations may perform the division regardless of if the if test passes or fails. The newer versions of the instruction set have a conditional move. It is often faster to perform the division speculatively then perform a conditional move without use of branch instruction. In this situation (conditional move) you may/will experience divide by zero.
/Qfp-speculation:off
might help (for the source files with the questionable statements).
And use /fpe:1 or /fpe:3
Note, use of /fpe:1 or /fpe:3 will generate NaN's and asumes it is your responsibility for detection of floating point errors.
Also,
If you are the programmer and NOT the research scientist using the progrma, then on every instance where you assume you want this test, you must verify with the scientist as to what result to generate. Do not assume 0.0 is the desired value. The correct value could be any of
error/abort
0.0
TINY (+/-)
NaN
denormal number
Each case may (generaly does) have a different set of rules.
Jim Dempsey
jim_cox
Jim,
Also,
error/abort
0.0
TINY (+/-)
NaN
denormal number
Jim Dempsey
Yes Jim - I'm the current mug programer tending this simple old codebase (sigh)
As stated in the title we need 0.0 / X = 0.0
If X = 0 crashes, thats ok
Thankx for the suggestiions re the switches. I'm wondering if some of the floating point options might influence. I'll keep playing...
We are trying to move to the IFort compiler so that we can take advantage of the multi-porcessor support, so any suggestions that improved reliability would be helpful.
Cheers
Jim
jimdempseyatthecove
When I converted a 700 file project from F77 to F95 (asside from some wierdness with DATA statements) conversion went rather well excepting for...
When converting from COMMON to MODULE some problems were exposed relating to EQUIVILENCE statements. The conversion to modules caught several problems relating to this but in the end was well worth the effort. The biggest initial improvement was in incorporationg allocatable arrays and use of pointers. The allocatable arrays meant the internal storage requirements could adjust according to input file parameters as opposed to being fixed at compile time to worst case. The pointers eliminated a lot of block moves of data in/out of working sets. The initial conversion attained 10x performance boost (principaly due to the appropriate use of pointers). Following that, compiler optimizations providing vectorization, then adding OpenMP. End result was 4 core system showed 40x+ improvement and provided for input file sizing of internal arrays. Your Milage May Vary.
One of the "hacks" I used to aid in the conversion was to extensively use the FPP. While keeping the majority of the code untouched, I could have the FPP redirect the once COMMON variables to use allocatable array and pointers. e.g.
#define SEGLEN pTether.pFiniteSolution.rSEGLEN
Placed in a xxx.INC include file permitted the code to continue to use SEGLEN(JSEG) without edits. Debugging was a little strange seeing that the InteliSence saw SEGLEN but the compiler saw pTether.pFiniteSolution.rSEGLEN. However, debugging was minimalized due to virtually no edits to working code.
There were several other conversion helpers the FPP provide in the conversion project.
Try to use all the tricks available - make life easy.
Jim Dempsey
jim_cox
Would be lovely to get that sort of improvemnt - we are only looking for 35 -50 % increase in speed
But for now I would just like to have one single program that works
