INQUIRE STATEMENT
steve_konarski
Débutant
1 479 Visites
I am uing theINQUIRE statement in a code. if the file exists the EXISTS is returned as .TRUE., however, I have extremely long file names ( including directories) and the combined length is 290 characters. Is this too long ?because say for instance the end of the file name is ..... ABCDEFG_001
then an INQUIRE on ..... ABCDEFG_002 also gives EXISTS as being .TRUE. giving the impression that INQUIRE only works on a set number of characters from the beginning of the filename
The form of the INQUIRE statement is :
INQUIRE (FILE = FNAME, EXIST = EXISTS)
0 Compliments
3 Réponses
Employé
1 479 Visites
The maximum path length on Windows is 260 characters. I haven't tested to see what happens with longer paths, but I'd expect INQUIRE to complain. Please file a support request with Intel Premier Support.
0 Compliments
Paul_Curtis
Précieux contributeur I
1 479 Visites
Here is a Win32 alternative:
FUNCTION file_exists (fname) RESULT (size)
IMPLICIT NONE
TYPE(T_WIN32_FIND_DATA) :: fdata
! fname is full pathname, null-terminated
CHARACTER(LEN=*),INTENT(IN) :: fnameINTEGER :: size, handle, rval
size = -1
handle = FindFirstFile (fname, fdata)
IF (handle /= INVALID_HANDLE_VALUE) THEN
size = fdata%nFileSizeLow
rval = FindClose (handle)
END IF
END FUNCTION file_exists
0 Compliments
jimdempseyatthecove
Contributeur émérite III
1 479 Visites
One of the techniques I have used in the past is to make use of the current working directory. Write a subroutine that:
a) gets and saves the current working on the drive of the pathfilename you are querying on (GETDRIVEQQ)
b) Attempt to set current working directory to a directory in the who's path in the pathfilename you are examining is the longest pathless than 260 characters long.
c) Use INQUIRE on current directory of drive for remainder of pathfilename
d) Restore the current working on the drive
This will get you up to 500 or so characters (assuming Windows doesn't choke).
You can modify this routine to nest deeper if need be.
Jim Dempsey
0 Compliments
Répondre
