29528 Discussions
INTEGER PARAMETER initialized with BOZ literal retains its BOZ literal status
jwmwalrus
Nouveau contributeur II
3 114 Visites
Hi.
The latest IFX seems to allow initialization of INTEGER PARAMETERs with BOZ literals, but further usage does not interpret such parameters as INTEGERs.
The following code
use ISO_C_BINDING
implicit none
integer(C_INT), parameter :: IN_CLOSE_WRITE = z'00000008'                       !! Writtable file was closed
integer(C_INT), parameter :: IN_CLOSE_NOWRITE = z'00000010'                     !! Unwrittable file closed
integer(C_INT), parameter :: IN_CLOSE = ior(IN_CLOSE_WRITE, IN_CLOSE_NOWRITE)   !! Close
end
Throws this error
$ ifx -V -stand f2023 -standard-semantics /media/vmshare/ior_boz.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.1 Build 20241113
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 25.0-1205.1
/media/vmshare/ior_boz.f90(5): error #8336: The arguments I and J must not both be boz-literal-constant.   [IOR]
compilation aborted for /media/vmshare/ior_boz.f90 (code 1)
debian@d
As I understand it, a BOZ literal is untyped, until assigned to an object with a specific type.
So my questions: is the code standard conforming but the feature is not ready yet in IFX?  Or are INTEGER PARAMETERs supposed to propagate its "initialized-through-boz-literal" status?
0 Compliments
13 Réponses
Steve_Lionel
Contributeur émérite III
3 082 Visites
The code is conforming to F2023, and BOZ status does not "propagate". You've declared the entities as INTEGER, so that's what they are. Intel Fortran has allowed using a BOZ constant to set the value of a PARAMETER for many, many years (as did DEC/Compaq Fortran before it.) This error message is puzzling to me.
jwmwalrus
3 071 Visites
@Steve_Lionel wrote:
Intel Fortran has allowed using a BOZ constant to set the value of a PARAMETER for many, many years...
Yes, I meant to say, "...without a warning when the -stand flag is given", which is the behavior I get with ifort.
Thanks for confirming the code is standard conforming, and that the error is an odd one.
0 Compliments
Xiaoping_D_Intel
Employé
2 934 Visites
A bug report has been opened. We will fix it in the future product.
0 Compliments
Ron_Green
Modérateur
2 526 Visites
This issue was fixed in version 2025.2.0
0 Compliments
jwmwalrus
431 Visites
Hi.
I have a variation of this one, using enums:
use ISO_C_BINDING
implicit none
enum, bind(C)
    enumerator :: IN_CLOSE_WRITE = z'00000008'                       !! Writtable file was closed
    enumerator :: IN_CLOSE_NOWRITE = z'00000010'                     !! Unwrittable file closed
    enumerator :: IN_CLOSE = ior(IN_CLOSE_WRITE, IN_CLOSE_NOWRITE)   !! Close
end enum
print*,IN_CLOSE_WRITE
end
The latest ifx throws
$ ifx -V boz-enums.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.3.3 Build 20260319
Copyright (C) 1985-2026 Intel Corporation. All rights reserved.
 Intel(R) Fortran 25.0-1601.5
boz-enums.f90(7): error #8336: The arguments I and J must not both be boz-literal-constant.   [IOR]
compilation aborted for boz-enums.f90 (code 1)
So, my questions once again: Since an enumerator doesn't explicitly state integer(C_INT) as type, is is the compiler right at complaining here? Is the code standard-conforming?
0 Compliments
FortranFan
313 Visites
@Igor_V_Intel / @Xiaoping_D_Intel  / @Shiquan_Su :
It appears IFX treats IN_CLOSE_WRITE / IN_CLOSE_NOWRITE as "boz-literal-constant" in OP's code rather than as enumerators viz. named integer constants.  May you please discuss with Intel Fortran team and follow up with an incident report as appropriate?
Thank you,
0 Compliments
Igor_V_Intel
Modérateur
193 Visites
Thank you for reporting it. Yes, it is a bug and I escalated it (CMPLRLLVM-75261)
jwmwalrus
2 514 Visites
Thanks for the notification, @Ron_Green .
This is a huge step in my attempt to migrate from ifort to ifx ---since I have like a million BOZ-literals that were never wrapped in INT(...) (I just suppresed the specific ifort warning).
Steve_Lionel
380 Visites
The code is not standard conforming as the standard does not allow a BOZ literal as an interoperable enumerator value. To make this standard conforming, place the BOZ literals inside INT().
0 Compliments
jwmwalrus
369 Visites
Hi @Steve_Lionel , thanks for the reply.
So, since the code is not standard conforming, it's actually a regression in regards to ifort's behavior (which is able to compile the code without issue).
$ ifort -V -diag-disable=10448 -standard-semantics -stand f23 boz-enums.f90 && ./a.out
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.13.1 Build 20240703_000000
 Intel(R) Fortran 2021.13.1-1693
GNU ld (GNU Binutils for Debian) 2.44
 8
 ifort doesn't even throw a warning, though ---as it does for non-int-wrapped BOZ literals anywhere else.
0 Compliments
jwmwalrus
362 Visites
@Steve_Lionel I see that the standards committee has ongoing work related to C23's explicit underlying type (i.e., a KIND selector) for interoperable enums. Would that work (if it makes it to F2028) lift the no-BOZ restriction? I mean
enum(KIND = C_LONG), bind(C)
end enum
would effectively be the same as `integer(C_LONG), parameter ...`, wouldn't it?
0 Compliments
Steve_Lionel
347 Visites
I was mistaken in saying that your code was nonstandard - the standard allows a BOZ as "the initialization for a named constant or variable of type integer or real". So, the compiler introduced a bug here. The BOZ is implicitly converted to the type of the named constant and should not carry forward its origin as a BOZ. My apologies for misrepresenting things earlier.
jwmwalrus
330 Visites
Thanks for the reply and verification.
So, if the code is standard-conforming, the issue is the same as before ---i.e., they fixed it for PARAMETER, but not for ENUMERATOR.
0 Compliments
Répondre
