INTERFACE to a MODULE PROCEDURE
Espen_M_
I try compiling the following code which is in a MODULE:
[fortran]
INTERFACE log
PROCEDURE::log_gen_2
END INTERFACE log
[/fortran]
I get an internal error message, while if I change the code to
[fortran]
INTERFACE log
MODULE PROCEDURE::log_gen_2
END INTERFACE log
[/fortran]
then the code compiles. It is my impression that the MODULE token is just optional for module procedure, and in that case this is a bug.
Yes, this is a bug that occurs when you try to extend an intrinsic (log here) without adding the MODULE keyword. This is our issue DPD200239082 which is not yet fixed.
This is fixed for a release later this year.
