ISOVAR Varying Strings
longthong
I stumbled upon ISOVAR varying strings in the CVF 6.6C3 samples library. It look like something I could use but there is no documentation. I moved the samples to my fortran library and executed the included dsw files. None of the 3 workes. They compiled ok but would not create a release folder andexecute. I get and error which states "Cannot execute program". Any ideas?
DT
anthonyrichards
New Contributor III
They run fine when compiled using CVF 6.6C, both debug and release. Are you by chance converting the sample work spaces to IVF and then compiling? If you are, then perhaps you are missing the build step and have to add it?
ISO_VARYING_STRINGS was published as an additional "part" of the Fortran 90 standard. In that form, it has massive memory leaks and should not be used. It has been removed from Fortran 2003. There is a variant around that uses ALLOCATABLE components rather than POINTER but it too has some issues.
longthong
I think I have just lost interest in ISOVAR. I hate memory leaks. Why doesn't somebody fix the code? The architecture looks good.
DT
Well, somebody did, using a feature that is now in Fortran 2003. but the standards committee never felt like accepting the change and just removed it from the standard.
