Hallo,
The sample code below is compiled with IVF v11.1.051/32-Bit on a PC running Intel processor.
REAL :: A, B, C
A = 2.0E-15
B = 3.0E-24
C = 1.0
C = C + A*B
print*, C
The explicit compiler flag combination is: /fpe:0 /fp:source /opt:1. The expected results 1.0 can be seen on any Intel processor.
This code just crashes on AMD processors (Athlon or Phenom), with "Program Exception : code 0x2b4 (269)
It looks like IVF has a problem with processing denormals on AMD processors.
There are remedies: /fp:precise ; /fpe:3 or /Qfpz-. At least one is almost acceptable.
What is not acceptable, in my case, is to build processor dependent executables.
Is that a bug or it is well known and expected?
Thank you.
Best regards.
Teo
Some older AMD processors can't handle the SSE instruction set (or SSE2/SSE3).
Linda
On the same machine, there is no corresponding bug with the 64-bit version of the compiler.
The bug is in an exception handler routine in LIBIFCOREMD.DLL Here is the source code:
[bash]program crash_amdCompiled with the 32-bit version 12 compiler, with options -fpe -traceback -Zi -MD and run, it produces the following machine code for line-6 of the source above
REAL :: A, B, C
A = 2.0E-15
B = 3.0E-24
C = 1.0
C = C + A*B
print*, C
end program crash_amd
[/bash]
[bash]C = C + A*B
00401055 F3 0F 10 45 F0 movss xmm0,dword ptr
0040105A F3 0F 10 4D F4 movss xmm1,dword ptr
0040105F F3 0F 59 C1 mulss xmm0,xmm1 <=== EXCEPTION TAKEN HERE
00401063 F3 0F 10 4D F8 movss xmm1,dword ptr
00401068 F3 0F 58 C8 addss xmm1,xmm0
0040106C F3 0F 11 4D F8 movss dword ptr,xmm1
[/bash]
and this call stack at crash time:
[bash]AMD_CRASH(void):The crash occurs when a NULL pointer is dereferenced at address 0x10029F9B. To add to the confusion, the error notification box that pops up is completely misleading:
10029F98 8B 50 28 mov edx,dword ptr [eax+28h]
10029F9B 0F B7 12 movzx edx,word ptr [edx] <== CRASH, edx=0
10029F9E 0F B6 C2 movzx eax,dl
> libifcoremd.dll!10029f9b()
[Frames below may be incorrect and/or missing, no symbols loaded for libifcoremd.dll]
crash_amd.exe!_for__nt_handler_jacket.() + 0x30 bytes
msvcr90.dll!785a9152()
msvcr90.dll!785a268b()
ntdll.dll!7d61ca3b()
ntdll.dll!7d61cb2b()
kernel32.dll!7d4dcd0c()
msvcr90.dll!78596cb8()
msvcr90.dll!78542f8c()
msvcr90.dll!78543161()
msvcr90.dll!785427b4()
crash_amd.exe!pre_cpp_init() Line 326 + 0x27 bytes C
msvcr90.dll!78542201()
crash_amd.exe!__tmainCRTStartup() Line 582 + 0x17 bytes C
kernel32.dll!7d4e7d42()
[/bash]
If the -MT option is used instead of the -MD option, the error occurs, but now the AMD_CRASH() routine code is in the .EXE file itself and the traceback is shorter. However, the immediate cause is the same: trying to access memory through a NULL pointer in EDX.
There is a known problem with the way the Fortran library handles floating point exceptions that occur during execution of SSE instructions. It is not sensitive to CPU manufacturer, but is sensitive to other things such as memory content. I believe this is fixed for update 1.
If you have set /fpe:0, then the underflow needs to get set to zero by the exception handler. This may or may not work right due to the bug we found. We should be releasing update 1 within a few weeks and I suggest you try it then. If it still fails, let us know and we'll be glad to investigate.
I find it intriguing that handling a 'denormal result' exception caused by the multiplication of two registers can be dependent on the contents of memory. Are there previous threads on this question that I may read?
Answering because Steve is temporarily unavailable, he may know more.
I presume you are using /fpe:0 because you wish to unmask the common floating point exceptions. For historical reasons, /fpe:0 also enables abrupt underflow (also known as flush-to zero), whereby denormals get set to zero. For some instructions, this happens in hardware; for others, in software. Its in this area that there appears to be a bug. Ive seen a somewhat similar bug in the C compiler/libraries, Im not sure if thats what Steve is thinking of. However, I have tested the forthcoming 12.0 compiler update, and I still see the problem, so well need to escalate this to the developers for further investigation.
If all you need is to unmask exceptions, and youarent concerned about the treatment of denormals, the simplest workaround is /Qftz-. Then all underflows are gradual, theres no flush-to-zero and you get IEEE arithmetic for denormals. If you intend something else, please explain, and we may be able to suggest other workarounds using RTL calls instead of command line switches.
Thanks for your replies.
This is not a pressing question. It is seldom that I use the troublesome option, and there are other means for locating underflow "errors". Now that Intel has become aware of the bug, I am content to wait until it is resolved in future issues of the compilers (C and Fortran).
I do not know if the OP agrees with my assessment of the importance of fixing the bug.
Your position is much appreciated.
Thank you all.
Teo
So, I'm wanting the abort on IEEE exceptions more than the underflow to abrupt 0.0 -- Is there another way to achieve that?
Linda
Linda
call ieee_set_halting_mode(ieee_usual, .true.)
This gives you more detailed control than /fpe:0, though that should also work, (in conjunction with /Qftz-, if you are running on a non-Intel system, until the above fix is made). I always compile my code with /traceback when I unmask exceptions; that way, I know immediately where the exception occurred, if it is inthe compiledcode. The overhead from /traceback is small, it's designed for use in production codes.
I have some little sample programs that illustrate the use of the Fortran 2003 intrinsics for IEEE arithmetic. I'll try to get them reviewed and approved for posting.
Linda
