IVF 11.1 + VS2008 + 2003 Server
Smorkalov__Mikhail
Hi there.
I have problem with Visual studio team system 2008 Version 9.0.21022.8 RTM and IFV 11.1.035 on MS Server 2003 Standart Edition.
OS and HW specification:
Host Name: BUILDSERVER
OS Name: Microsoft Windows Server 2003, Standard Edition
OS Version: 5.2.3790 Service Pack 2 Build 3790
OS Manufacturer: Microsoft Corporation
OS Configuration: Member Server
OS Build Type: Uniprocessor Free
System Type: X86-based PC
Processor(s): 1 Processor(s) Installed.
[01]: x86 Family 15 Model 2 Stepping 4 GenuineIntel 2266 Mhz
BIOS Version: ASUS - 42302e31
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Due to our migration from VS 2005 to VS 2008 we bought IVF 11.1 and tried to install it on our build server.
It installed well, though in fully integration with VS 2005 and totally disrespect to VS 2008.
I know I checked twice that I chose both VS boxes when install. But VS 2008 lives without IVF.
I deinstalled VS 2005. And reinstalled IVF. No result.
I modified IVF few times via "Add and remove programms". Still no luck. It emulates some work and does nothing.
The main point is: this VS 2008 distro works fine with this distro IVF 11.1 on Windows XP SP2 and has no problem with already installed VS 2005. Checked on at least 3 different machines.
I don't know what to do next, please help!
This combination should work. What happens if you run the attached program? Does it show any error messages?
Smorkalov__Mikhail
Thanks a lot, this programm helped!
