I have Compaq Visual Fortran 6.6 with IMSL 4.01 and Intel Visual Fortran 11 without IMSL. Is it possible to use IMSL 4.01 library that was bundled with CVF in Intel Fortran?
I've added paths to LIB and INCLUDE directories: C:\Program Files\Microsoft Visual Studio\DF98\IMSL\LIB and C:\Program Files\Microsoft Visual Studio\DF98\IMSL\INCLUDE
I have a source code as:
real*8 function bla-bla()
use numerical_libraries
call DQDAG(intKFunc, xi1, xi2, eps_kIntAbs, eps_kIntRel, 1, summ, err)
end function
And when I try to build solution, I have 24 errors:
Error 1 error LNK2001: unresolved external symbol __OtsMove imsls_err.lib(e1psh.obj)
Error 2 error LNK2001: unresolved external symbol __OtsMove imsls_err.lib(e1init.obj)
Error 3 error LNK2019: unresolved external symbol __OtsMove referenced in function _DQDAG imsl.lib(DQDAG.obj)
Error 4 error LNK2001: unresolved external symbol __OtsMove imsl.lib(DQ2AG.obj)
Error 5 error LNK2001: unresolved external symbol __OtsMove imsl.lib(DMACH.obj)
Error 6 error LNK2001: unresolved external symbol __OtsMove imsl.lib(E1USR.obj)
Error 7 error LNK2019: unresolved external symbol __FIIfexp_ referenced in function _DQ7AG imsl.lib(DQ7AG.obj)
Error 8 error LNK2001: unresolved external symbol __FIIfexp_ imsl.lib(DQ8AG.obj)
Error 9 error LNK2001: unresolved external symbol __FIIfexp_ imsl.lib(DQ4AG.obj)
Error 10 error LNK2001: unresolved external symbol __FIIfexp_ imsl.lib(DQ9AG.obj)
Error 11 error LNK2001: unresolved external symbol __FIIfexp_ imsl.lib(DQ5AG.obj)
Error 12 error LNK2001: unresolved external symbol __FIIfexp_ imsl.lib(DQ6AG.obj)
Error 13 error LNK2019: unresolved external symbol __OtsStringCompareEqlPadded referenced in function _E1USR imsl.lib(E1USR.obj)
Error 14 error LNK2001: unresolved external symbol __OtsStringCompareEqlPadded imsls_err.lib(e1pop.obj)
Error 15 error LNK2019: unresolved external symbol __OtsMoveMinimum referenced in function _E1PSH imsls_err.lib(e1psh.obj)
Error 16 error LNK2001: unresolved external symbol __OtsMoveMinimum imsls_err.lib(m1vech.obj)
Error 17 error LNK2019: unresolved external symbol __OtsFill referenced in function _E1PSH imsls_err.lib(e1psh.obj)
Error 18 error LNK2001: unresolved external symbol __OtsFill imsls_err.lib(e1init.obj)
Error 19 error LNK2001: unresolved external symbol __OtsFill imsls_err.lib(m1vech.obj)
Error 20 error LNK2019: unresolved external symbol __OtsStringIndex referenced in function _C1TCI imsls_err.lib(c1tci.obj)
Error 21 error LNK2019: unresolved external symbol __FXDMOD referenced in function _E1UCS imsls_err.lib(e1ucs.obj)
Error 22 error LNK2001: unresolved external symbol __FXDMOD imsls_err.lib(e1ucs.obj)
Error 23 error LNK2001: unresolved external symbol __FXDMOD imsls_err.lib(e1ucs.obj)
Error 24 fatal error LNK1120: 7 unresolved externals Debug\filtration_batch_intel.exe
Is it possible at all to use CVF IMSL 4.1 in Intel Visual Fortran?
Not possible. The CVF IMSL is Fortran code compiled with CVF - you cannot mix objects from any other Fortran compiler with those from Intel Fortran.
But can you not use CVF to build a Windows 32 bit staticlibrary containing wrappers to IMSL routines that can then be linked to by any other compiler?
You could build a DLL that does this - not a static library - but the IMSL license has wording prohibiting distribution of IMSL in a way that provides IMSL access to another application. You'd want to be careful what you did with this DLL.
