29280 Discussions
IVF 8.0 and VS.net Mixed Language Programmin
Deleted_U_Intel
First, I apologize for asking a question that's probably aleady been answered by Steve a dozen times.I'm using IVF 8.0.1877.2003 and VS.net2003. I have a mixed FORTRAN and C language solution where I've put all the FORTRAN code into a project that builds a static library and the C code into a separate project that builds Win32 executable. The C code does all the GUI stuff, calls the FORTRAN code to crunch numbers, and the FORTRAN code passes some status info back to the C Code which displays the info in a status window. I have the build order of the projects set so that the FORTRAN builds first and then the C code. Here are the pertinent code chunks:
In the C header file
extern int __stdcall VORINP( int*, int*, int* );
In the C code
void HandleExecuteVorlax(...) {
int arg1, arg2, arg3;
dum = VORINP( &arg1, &arg2, &arg3)
In the FORTRAN code
INTEGER*4 FUNCTION vorinp( var1, var2, var3 )
INTEGER*4 var1 [REFERENCE]
INTEGER*4 var2 [REFERENCE]
INTEGER*4 var3 [REFERENCE]
vorinp = 1
return
When linking, I get the error
vorexecute.obj : error LNK2019: unresolved external symbol _VORINP@12 referenced in function _HandleExecuteVorlax
I originally coded this up using CVF 6.6 and VS 6.0, and everything worked fine. I then migrated to VS.net2003 and was able to make this work by building the FORTRAN as a static library and adding it as a resource to the C code project. Unfortunately, however, I'm stumped as to how to make this work with the IVF compiler.
Thanks in advance for any help!
Doug
Take out the __stdcall in the C declaration of the Fortran routine. Intel Fortran does not use STDCALL as the default.
Do you also get errors that libraries are not found? You may need to add the paths to the IVF libraries to your Tools..Options..C++..Directories (I think - I'm not using a PC with the compiler installed right now.)
Well, I do check in here off hours...
I can't tell from your description just what you have so far. Can you upload a zip file that has your .sln, .vcproj, .vfproj and .log files from the solution?
