Hi Steve,
Ok, I'm spoiled by the CVF6.
I bought the IVF 8.1 (w_fc_p_8.1.019) in the download-version.
The first error was:
Microsoft Visual C++.NET 202 or better is required to install .. for 32-bit applications. Please select from the following two options
I havent read in the program description (perhaps I read over this) that I need the C++-compiler. I havent it on my computer. I bought IVF8.1 as _executable_ program.
The next error was:
Missing Pre-requisite Microsoft Platform SDK* not found
Comment above
After the end of the installation I saw only the two Debuggers and the Array Visualizer. I started the Debugger and read:
idb.exe Component not found .missing MSVCR71.dll
After this I stopped and later I looked for comments about IVF8.1-installation in your forum. I saw your advice to load the C++ Toolkit. I wrote the comment, knowing that you are a very helpful man, and planed to install this Toolkit (with your new suggestions) on Monday and to try the IVF8-installation after this (Toolkit-installation) again.
Now, I did so (on Saturday) and I have mistake 1 and 3 again L
What can I do? Have I to buy(!) the C++.net ? I bought IVF8 as executable program like CVF6 earlier!
Regards and many thanks for your help
(I hope Im able to finish the installation on Monday)
Ute
