IVF 9 & NAG Library
garyindia
We are trying to run basic example program a02aafe.f in the NAG
Library at command prompt.
It compiles succesfully, however, it says, while executing
"The ordinal 528 cld not be located in the dynamic link librry
libguid40.dll.
Doing a search for libguid40.dll gives several libguides, as in
Libguide for NAG/IFC/MATLAB. How does one ensure correct one is being
accessed?
However, it runs asks for input values when run from windows(as in
double
clicking). But after taking input it just goes away.
Also, if you dont give input redirection in Windows, the build is
successful, however, when u run with Debug it gives following errors:
abc.exe': Loaded 'C:WINDOWSsystem32imagehlp.dll', No symbols loaded.
'abc.exe': Loaded 'C:WINDOWSsystem32msvcrt.dll', No symbols loaded.
'abc.exe': Loaded 'C:WINDOWSsystem32shimeng.dll', No symbols loaded.
'abc.exe': Unloaded 'C:WINDOWSsystem32shimeng.dll'
The program '[2464] abc.exe: Native' has exited with code 0 (0x0).
AND
If you run without debug:
A windows opens which says press any key to continue.
Can you please help?
> > libguid40.dll.
> > accessed?
Make sure that C:Program FilesIntelCompilerFortran9.1IA32Bin is
included in the definition of the PATH environment variable, before
other folders that may contain libguide40.dll. You have to check the
box at compiler install time to have this done for you, or you can do it
yourself. If you don't, then programs linked against the Intel Fortran
DLLs won't run. You apparently asked for a parallel processing option,
which uses libguide40.dll.
> > double
It is simply exiting. You'll have to debug your application to find why.
These are not errors. The first four messages are simply informational
from the debugger saying that these DLLs are loaded as part of the
program but there is no debug info for the DLLs. Quite normal.
The last message says that your program exited normally - perhaps
because it sees that it has no input. This is in your program's logic.
Same thing.
Intel_C_Intel
Gary,
You might also want to check your NAG licensing situation. If you have the 'wrong' kind of licenses NAG won't work. We had problems with a NAG library that was licensing itself on a per machine basis, preventing us from redistributing our exes.
mittalgirish
Judd,
There are no NAG Licencing issues as we are currently using only the trial licence and trial licence works fine on any machine.
Gary
mittalgirish
---> No parallel processing option, we are trying to compile a simple program aa02aafe.f, which finds square root of a complex number.
>>double
----> As I said, it is simple NAG example program a02aafe.f, which works fine on CVF. It opens a window, where you give the data and it computes results for you.
Same thing.
----> Again, I dont think there is any problem with the code. Its just something is missing somewhere....
On a side note:
Why does Intel support has to be so complicated. Why can't I just send email and get a reply. Intel has information on all the customers who have purchased their software.
You see it is difficult to remember so many passwords/log in information.
