29607 Discussions
IVF-CVF difference wrt data statements
mkummert
IVF seems to handle successive data statements differently from CVF. The program here below illustrates that:
program Test
implicit none
integer :: i
real(8) :: array(3)
data array/3*-999/
data array(1)/11/
write(*,*) (array(i),i=1,3)
end program Test
The results are:
in CVF 11 -999 -999
in IVF -999 -999 -999
I assume successive data statements for the same array are just a bad idea, but is there a way to obtain the CVF result with IVF?
Michal
Message Edited by mkummert on 05-05-2004 03:40 PM
The program is illegal. You're not allowed to initialize the same element more than once. If it "worked" in CVF it was by coincidence, not design.
durisinm
In the section describing the DATA statement my DVF and IVF language reference manuals both state that a variable can be initialized only once in an executable program. What you're observing with CVF is probably nonstandard behavior and could be a bug. I wouldn't trust any workaround to duplicate that behavior in IVF--if it even exists. It could change at any time in the future.
The better option is to change your code. One possibility is to change data array/3*-999/ to data array/11, 2*-999/, although I recommend using data array/11.d0, 2*-999.d0/ since array is the real(8) type.
Mike
mkummert
Thank you both for your answers.
DATA statements like :
DATA array/11.d0,2*999.d0, etc.
would be hard to read in the real program (big arrays with only a few spots reassigned) so I just used an initialization routine that is easy to read.
sblionel wrote:
The program is illegal. ...
I will report the programmer to the competent authorities ;-)
Michal
