29601 Discussions
IVF Compiler fixed format error - illegal character
postaquestion
Is there a way to compile this program?
PROGRAM HELLO
WRITE(*,1)
1 FORMAT('Hello World')
END
ifort doesn't like the FOR in columns 4,5,and 6. I have some source (hundreds of files) that is fixed format but labelled lines like format and continue don't start in column 7.
Illegal character in statement label field.
thanks.
The only way that our compiler would accept that as "fixed form source" (.f or .for file type) is if the character following the 1 was a tab and not a blank. We support an extension called "tab source form" which you can look up in our documentation.
Otherwise, I would say that this is really a free-form source and should be compiled as such. You can use /free as an option if the file type is wrong.
If you really have hundreds of files like this, then either they have been corrupted or are really free-form source with the wrong file type. I don't know of any Fortran compiler that would accept this as fixed-form source.
joerg_kuthe
I haven't tried but I am quite sure that you can compile your program using the /FREE option.
Regarding your other fixed format files with FORMAT and CONTINUE statements not starting in column 7 or beyond, I suspect that there is a horizontal tabulator character (HT, ASCII 9) being used at the beginning.
I knowa compiler which accepts this and interprets HTas 8 characters, so this compiler would accept your sources. However if several HTs are used in a line of code, you might encounter the problem that the compiler tells you that thissource line is too long (> 72 or > 132 characters, respectively).
I don't know how IVF is handling HTs. From your experience I guess that an HT is taken as one character.
Joerg Kuthe
www.qtsoftware.de
dobrien
Thanks for the replies.
It was my preprocessor. The Makefile was calling cpp which was removing the extra spaces. I changed the makefile to the Intel fpp for the preprocessor and it's working much better now.
By the way, free-format didn't work either because there were C's in the first column for comments instead of !'s.
