IVF Composer XE 2013 hangs
Jon_D
New Contributor II
I recently installed IVF Composer XE 2013 and am trying to re-compile my source code.  However, the compiler hangs during compilation of a specific file without any error or warning messages.  This happens both for Win32 and x64 configurations.  The same code compiled and ran with no problems with the previous versions of the compiler (12.1.6.369 and 12.1.5.344).
Is this an issue other users have run into? Is there a way to fix the problem or should I submit this to the Premiere Support?
I am using VS2010 Professional on a Win7 system.
Thanks for any help,
Jon
Lorri_M_Intel
Yes, please ... submit a reproduceable example to Premier. The quicker we see it, the quicker we can fix it! :-) thanks -- --Lorri
