29383 Discussions
IVF and CVF compiler errors - what does it mean?
lklawrie
Warning: Only rename information from the ONLY qualifiers for this external module will be processed since all entities from the external module have been declared public [DATAHEATBALFANSYS]
Most of our data modules are "PUBLIC" -- this is the only one that is tripping this warning
Linda
If you could provide a small sample, it would be easier to respond. If I had to guess, it might be that you have a USE with ONLY but all of the symbols named have already been made visible through a different USE so the ONLY is ignored other than the rename clauses. What happens if you remove the ONLY (and leave just renames, if you have them)?
lklawrie
oh, i hate those. just started appearing so it looks like something other module might have changed things so that this is being USEd. there are no renames.
now, i just have to remember which modules... I will try to create a small sample tomorrow.
Linda
I will say that this warning seems rather pointless. If you (or I) can come up with an example that triggers it, I may be able to convince the developers to turn it off.
lklawrie
Well, I think i see it, without having to generate an example file.
in the routine.. there is:
USE Datax, ONLY:
USE DataThis, ONLY:
USE DataThis
so, someone slipped a USE total in with a USE ONLY in the same routine.
(I don't think it was me)
Linda
Bingo! That's exactly it. The following source reproduces the warning:
[plain]module mymod
integer x,y,z
end module mymod
program main
use mymod, only: x
use mymod
end[/plain]
I will discuss this with the developers.
Jugoslav_Dujic
Valued Contributor II
For what it's worth, the warning makes sense to me, if only it were formulated in plain language. Along the lines of:
"This ONLY list is spurious because the symbols are visible through another use-association."
