29487 Discussions
IVF is not loaded into Visual Studio
rase
Once I used a running installation with VS 2005, IVF and IVC V10. I installed IVF V11 Beta. When IVF V11 was available I deinstalled the beta version again, and installed V11 (61 and 66). Sincethe beta deinstallation I receive the message (in German) when I try to change the Fortran options:
Intel Fortran Tool Options Package ({0DE3E8C5-8C7F-4C1F-97D6-59D5AEBDAFFC}) was not loaded
I reinstalled the whole sequence of VS, IVF andIVC twice, but the message did not disappear. I use Windows XP SP3 and VS 2005 (German) with SP1. Any suspicions what could be wrong and suggestions how to fix it? Greetings, Wolf
In the text below, substitute "2008" for "2005" if you are using VS2008.
First, locate the folder containing IntelPkg.dll, IcUtil.dll and OptPkg.dll. This is usually:
C:Program FilesIntelCompiler11.0nnnCompilerVS IntegrationC++VS2005
If those DLLs are not present, then uninstall and reinstall Intel C++.
Close Visual Studio if you have it running.
Start > All Programs > Microsoft Visual Studio 2005 > Visual Studio Tools > Visual Studio Command Prompt
This will open a command prompt window. Set default (cd) to the folder containing IntelPkg.dll. Type the following commands in this exact order:
regsvr32 /u icUtil.dll
regsvr32 /u IntelPkg.dll
regsvr32 /u OptPkg.dll
Each of these should display a message box saying that the DLL was successfully unregistered. An error in this step is usually not harmful, but should be noted.
Now type these commands in this exact order:
regsvr32 OptPkg.dll
regsvr32 IntelPkg.dll
regsvr32 icUtil.dll
Again, you should get a message box, this time saying that the DLL was successfully registered. If you get an error here, stop and report it.
Assuming that all three DLLs were properly registered, type:
devenv/setup
This command may take several minutes to complete. When it returns to the command prompt, wait three more minutes before starting Visual Studio.
If this does not help, I suggest asking in the Intel C++ forum section.
Uninstall IVF. If there is an "Intel Fortran" folder under Visual Studio 8, delete it. Reinstall IVF. Then run the program in the attached ZIP.
rase
Thanks a lot, Steve, everything worked fine for IVF. But I had to find out that the Fortran error message masked the same problem with IVC++:
Intel C++ Compiler Integration Package, Property Pages ({D6EEEC80-45EA-4CA7-AE30-74700CA09F81}) not loaded.
The exe you attached to your reply did not work for IVC++. Do you have a solution, or should I contact the C++ people?
I'll get back to you tomorrow with a suggestion for Intel C++. I don't have a repair program for it, but you can do it manually.
regsvr32 OptPkg.dll
regsvr32 icUtil.dll
devenv/setup
rase
Steve, thanks for your efforts to solve the problem (caused by the Beta installation, isn't it?). When I try to execute the regsvr32 command exactly as described I get the message that the command is unknown. I tried to use the command option in Start, but this attempt failed as well. I will open a thread in the C++ forum, maybe somebody has an exe or script to get rid of that nasty problem. Greetings, Wolf
Ah, I've run into a few systems like that. Right click on My Computer, select Properties, Advanced. Click Environment Variables. Under System Variables, select PATH and click Edit. At the end, add:
;%SYSTEMROOT%;%SYSTEMROOT%system32
Click OK, OK, OK.
Now start a new command prompt window and try it again.
rase
Thanks again, problem is solved. Greetings, Wolf
